cassidyp's Avatar
Wire identification help
First wire is black with purple stripe. 2nd wire is solid black. Can you tell me what they are from / do? and where they get connected?
There is a male connector on the distributor and it looks like the black wire with purple stripe gets a female connector attached and connects to this part.
The shorter black wire appears to have been cut also. Wire is solid black.
I have additional images if they will help in identifying these.
72 911 Targa VTK Member 110245
71 911 Targa
68 911 non sunroof Coupe
Gruppe B # 3911
http://www.pelicanparts.com/gallery/cassidyp
Old 02-21-2006, 08:49 AM
Friend of Warren
black and purple wire should be for your tach.
Kurt V
Old 02-21-2006, 08:58 AM
cassidyp's Avatar
Kurt,
The black and purple wire is the "power supply" to the tach. Should it be connected to the male prong on the distributor?
(I realized looking at the image that I have to re-route my wires under the connecting linkage too. D@mn it!)
I should have disconnected these and I would have had a better idea where they went. Trying to use my 71' car as a guide.
Patrick
71 911 Targa
Gruppe B # 3911
Old 02-21-2006, 09:47 AM
Early_S_Man's Avatar
Porsche Crest
Patrick,
Both Black and Black/Violet wires should be piggybacked together at the distributor trigger connector to the points ... both of these wires are trigger sources ... for the CDI unit, Speed Switch, and tachometer!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-21-2006, 09:55 AM
cassidyp's Avatar
Warren,
Once again Thank you so much!
It is really great that you so willingly share your knowledge and information with folks on this board. I can tell you it is a major reason I purchase stuff from Pelican (to support this source) and had the b@lls to try to rebuild this entire car myself.
It is getting pretty close now too!
Patrick Cassidy
71 911 Targa
Gruppe B # 3911
Old 02-21-2006, 10:16 AM
