Bilstein insert
Hello,
I need some help. On my '73 T Targa I have black or grey strut here are picture (at the end of the link) http://www3.sympatico.ca/vadim.siegel I would like te remplace with Green Bilstein. Pelican Parts service told me that I need to remplace with Boge. I can read in the forum that Blistein insert can be used in Boge strut ... Can you help me about that ? Thank you !
Vadim 1971 911S Targa |
Yes, you should be able to use the Bilstein insert. I have Boge struts (black) and changed to Bilstien inserts. I had to undo the brake line to get the strut out far enough to clear the fender when I installed. Seems nobody else has had to, that I know of. Maybe I got short brake lines.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
sidebar question...Did you disconnect the charlie bar up front? Looks like you have the drop links but from those photo's you can't see the rest of the sway bar.
Tony G 2000 Boxster S |
Your right. I have to change the drop link it is broken...
A Bilstein insert for a Boge strut is not interchangeable w/ a Bilstein insert for a Bilstein strut.
Your choices are[list=1][*]Buy a Bilstein insert for whatever strut you have[*]Buy a new set of struts, which will include the proper insert[/list=1] If you chose the latter, Bilstein 911 strut and 930 srut are interchangeable, the 930 just come with Bilstein HD inserts The Bilstein struts only come w/ 3.5" ears, they are not compatible w/ T calipers, so you will need to update the calipers should you go this route
