911/930 Front Lower Control Arm (A-Arm) Compatability
Can anyone tell me if 930 front control arms are interchangeable with 1971 911 a-arms? Also, if they are not what is the difference or could someone refer me to a source of information that could explain the differences?
Thanks In Advance.
Dan |
They would bolt into place ... but they have the wrong mounts for you anti-roll bar links. The loops would have to be cut & ground off to affix 'U-tabs' for the through-the-body anti-roll bar linkage to hook-up properly. Not a major project, but since the last 930 was built in 1989 ... you have to deal with the issue of worn-out bushings sooner or later! Unless your control arms are bent or rusted-out, why not just clean, repaint, and replace the bushings?
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
A-Arms
Warren,
Thanks for the information. I have the opportunity for purchasing a set that seem to have the tabs for the earlier car, but the seller is claiming that these arms for a 930 but they have the early tabs that seem to accomodate the early through body sway bars. I was thinking that if I could have a seperate set that it would be easier to rebuild them and than install and sell the originals. Thanks Danb
Dan |
The early 930s had the thru-body sway bar. I'm not sure about the late ones.
Chuck Moreland - elephantracing.com - vonnen.com |
Later 930s have the later style, one-piece sway bars.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
