Ferrariguyma's Avatar
Send a message via AIM to Ferrariguyma
Question Removing center console on a SC BUT keeping A/C Controls? 911SC Where to mount them?
I really like the look and added space (even if it seems bigger) removing the center console allows. I am still on the fence about removing my A/C entirely. One of the cars PO's upgraded the A/C system to a Kuehl system and we do have some pretty hot, humid summer days here in MA. My question - Can the center console be removed and the a/c controls be repositioned somewhere else? Has anyone on the list done this? Pics?
Some ideas I had:
Move the A/C controls to a smaller "pod" in the exact same location just cut the top part of the console and screw the top part of the console to the floor. Removing the rest of the console.
Move the controls to a discrete place mounted to the floor under the drivers or passenger seats.
Any suggestions or "found" solutions would be welcome.
THANKS!
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed
Old 02-24-2006, 11:09 AM
sushinav's Avatar
If you have deleted your stereo too, putting them on the blanking plate there would look good. Another thought is to remove your ashtray and fab a small flat panel there that could hold the controls.
...sick with gearheadia
Old 02-24-2006, 11:17 AM
Andrew,
I did something similar. Realize that your limited by how far you can extend the "temp control" knob, as it includes a capilallary tube filled with freon that cannot easily be extended. This said, an under the seat location is a stretch.
I took the simpliest approach and gutted my ash tray and mounted the 2 control knobs in the "ash" portion of the ashtray with the knobs located below. While you can't see the controls, their functions are pretty obvious.
Hope this helps
Vin
Old 02-24-2006, 11:18 AM
don911's Avatar
Not the ac switches but in this thread, there's a picture of my flasher and rear window defrost switches moved to the stereo location.
Gauges in lieu of Radio ?
If you want stereo, you could fab up a small underdash console using the ash tray area as a mount.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-24-2006, 11:47 AM
Thumbs up Vin and Don. Both excellent ideas!
Vin do you have any pictures of the install?
Thanks!!!!
This list is fantastic!
Old 02-24-2006, 11:58 AM
Sorry, no pictures since the car is tucked away for the winter.
This is actually a pretty self explanatory relocation of these 2 switches. They fit the ashtray with a bit of cutting and grinding without issue and clean up the look of the interior without the center console.
If your a stickler for keeping your car original, pick up a used ashtray and tuck your original away somewhere. For me this isn't much of a concern.
Old 02-24-2006, 12:48 PM
Question Vin Question...
Is there enough wire/tubing to run to the very back of the "firewall" and then up under the dash to the ashtray? Or did you have to extend the wire and freon tube?
This seems like the perfect solution.
Thanks for you help
Old 02-24-2006, 01:03 PM
Andrew,
More than enough tubing/wiring. The capillary tube actually exits the firewall up near the center bowtie vent under the dash. This passes into the front trunk and goes into the smugglers box.
Same goes for the electrical leads to the switches. They come down and into the floor console, so relocating them to now go up to the ashtray is a no-brainer.
Once you pull thinks apart it will all fall into place.
Vin
Old 02-24-2006, 01:10 PM
Thanks Vin!
Im going to go for it.
Old 02-24-2006, 03:19 PM
SiennaSC
Removing console on an SC but keeping the A/C controlls
I'm a new member and this is my first post on this site. I acquired some good information from this thread so decided I would post what I ended up doing in case someone else finds it useful.
I also wanted to delete the center console but wanted to keep the A/C.. at least for now. I didn't want to cut any holes and wanted the controls to be somewhat hidden.
I ended up fashioning this bracket that I attached to the back of the ashtray mount.
Now to cover the holes left behind I had a vinyl patch made that I glued over the top of the existing vinyl.
Finished look..
Thanks for all the great information on this site.
Last edited by caloldvine; 01-27-2013 at 02:13 PM.. Reason: swapping in a better picture
Old 01-27-2013, 01:44 PM
SiennaSC
Better pic.
Old 01-27-2013, 02:21 PM
Demetri's Avatar
That looks great! Nice work!
Old 01-27-2013, 09:40 PM
Here is my recent solution to this problem. Mounted controls with "project box" from radio shack. Plugged center hump hole w/ grommet and painted aluminum plug. Smaller console mount holes plugged with factory screws using black plastic screw caps.
Old 11-06-2014, 09:39 AM
82 911 SC - Ancora Imparo
Reviving an old thread. These are some great ideas and they don’t look too difficult to undertake. I will certainly post my results after it is completed. Thanks guys!
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 02-06-2019, 05:28 PM
I'm good with tools.
AG81's Avatar
Moved my A/C controls, rear window defrost and hazard controls to the radio location.
Console delete also. Blue tooth under the passenger seat.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 02-06-2019, 06:16 PM
fred cook's Avatar
I removed the ash tray and made a mounting plate to go in that area. The wiring and cold control tube reached perfectly.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 02-06-2019, 08:32 PM
El Duderino
tirwin's Avatar
And I got the idea from Fred.
Fred helped me with a mock up and then I ended up with this as the final solution.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 02-06-2019, 08:50 PM
Vintage Owner
Jack Stands's Avatar
As I don’t think many folks ever use the ashtray, it seems like a wonderful location for the controls. A 3D printed mount that would house the controls in the ashtray space would be a great project!
84 Targa (sold)
70 914-6 (sold)
73 914-6 2.7 conversion (sold)
75 GMC Motorhome (sold)
2016 Cayenne
Old 02-07-2019, 08:58 AM
Old 02-07-2019, 09:15 AM
El Duderino
tirwin's Avatar
Yes! I have been meaning to get into 3D printing with my copious spare time. :rollseyes:
But this was one of the first things I wanted to try.
Old 02-07-2019, 11:37 AM
