OK, what did I kill?
I had the engine/tranny out of my car ('94 Turbo 3.6) and put it back in this weekend. The install went easily and I thought I hooked everything up. The car struggled to start as it would barely turn over at first. I thought I had a bad battery. Ultimately I tinkered with a jumper battery and whatnot and the car started and ran great. I backed it up and out of my driveway and it died just as I went over a hump. It would not restart. I thought I had a crappy battery so I bought another.
The new one would not turn over the car and the tach needle bounced all over when trying to start it. I recognized the bouncing needle as a bad ground connection and immediately went under the car and noticed I had forgotten to connect the ground as the wire had been squashed up by the transmission and out of sight. I connected it to the one of the two nuts holding the starter on (is this right? honestly, I didn't remember which one it went on) and now the car turns over perfectly with no needle bounce. The problem is that it doesn't catch and run.
I fear I killed something by not having the ground connected right (er, at all). I'm hoping it is just a relay or fuse. Any suggestions what to look at? I've checked many fuses and all are fine. Could I have killed the control unit's relay? Could I have killed the control unit?
Old 02-27-2006, 05:20 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
Bad ground? Check your ground straps...
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 02-27-2006, 06:27 PM
RETIRED
Joe Bob's Avatar
That be my guess, trans strap to ground.
2012 ML350 3.0 Turbo Diesel
Old 02-27-2006, 07:06 PM
I put that back on (see middle paragraph). Still no starting, but it turns over nicely now!
Old 02-27-2006, 07:07 PM
RETIRED
Joe Bob's Avatar
Check power to the DME box....
Old 02-27-2006, 07:09 PM
Turning over good but no starty? No spark or no fuel.
Matt J.
Old 02-27-2006, 07:11 PM
Now in 993 land ...
aigel's Avatar
Are you sure you have the ground bolted to the car side and not looped on itself on the trans / starter?
I doubt you killed anything.
George
81 SC (sold)
Old 02-27-2006, 07:46 PM
Make Bruins Great Again
Por_sha911's Avatar
Check your fuses.
Joe
Old 02-27-2006, 08:32 PM
