Eric,
Nice project! Clever solutiosn to some problems! Who makes the sound deadening product? Kind of looks like WURTH SKS undercoating? Doug |
I have to look in my notes...it is made by a co that specializes in high end audio installation...they are located in oregon....it goes on purple and dries gray
update....starting spraying the special epoxy paint that will be used on underside, front trunk, engine compartment and interior...tinted to mexico blue color...super durable industrial coating "Ameron Amershield" we will bolt up basic suspension and roll off to paint shop next week for the good stuff (2 stage) on the sunny side of the car...http://forums.pelicanparts.com/uploa...1146264216.jpg http://forums.pelicanparts.com/uploa...1146264240.jpg http://forums.pelicanparts.com/uploa...1146264270.jpg
sound damping spay on reply to doug
called vdix made by cascade audio....sprays on dries to 8lbs a gallon weight
They have a web site www.cascadeaudio.com
- not sure what vdix is tho, maybe a type in one letter? - BTW, they say they hae speaker panels for Porsches now... You have done several great tricks on your car! More pics! |
cleaned fan/housing/engine a few weeks ago, installed elephant polybronze on a arms and monoballs on banana arms, polybonze on springlates...bolted up front suspension today...repainted front struts, swaybar hardware etc, and used eastwood cad paint on rear spring plates...expect it to go to paint next saturdayhttp://forums.pelicanparts.com/uploa...1147027495.jpg http://forums.pelicanparts.com/uploa...1147027553.jpg
b
d
b
SWEET!
for some reason, pics not posting, even when I dnsize to 200kb
reduce the resolution -- in Irfanview, hit CTL-R then select something like 1200x1600 -- once posted you can go back and delete the black screens
we are all breathlessly waiting for those pics! |
Hey Man!
Your doing a great gob!;) I to like the oil cooler panel! In fact so much that. I am gona use some of the used ones I have up. :eek: Great Idea. You gona have a ball driving it when you getter done!:D SmileWavy |
jambs painted brought in for full paint tonight! http://forums.pelicanparts.com/uploa...1148603739.jpg
excelent thread...i am officially subscribed :)
Rennschweiner:
Small ( but maybe important) point..... Don't forget to install the little "braces" on the oil-fed cam tensioner lines...you don't want vibration to shake the little bugger silver- soldered "ends" loose !..... makes for a horrible oil mess...possible "lunched" engine.... and a bad hair day. - Wil |
Mike does great work! Who's spraying?
| All times are GMT -8. The time now is 08:19 PM. |
