-   -   cloning experiment...long (http://forums.pelicanparts.com/porsche-911-technical-forum/269103-cloning-experiment-long.html)
Elombard 11-04-2006 05:25 PM
Here is a pretty good idea of what the black will look like, I thought about white, orange, silver and grey, in the end I thought it needed to match the wheels. White Fuchs and script would look cool?
ALso, what mag wheel cleaner did you use on the tranny? Was it specifically for magnesuim wheels?
http://forums.pelicanparts.com/uploa...1162689748.jpg
http://forums.pelicanparts.com/uploa...1162689884.jpg
ericwitte 11-05-2006 03:38 PM
i think i used mothers mag wheel cleaner
shamrockcustoms 11-05-2006 04:29 PM
looks great so far..cant wait to see more
Jay
ericwitte 11-05-2006 06:25 PM
finally broke 100th post!
Facey 11-05-2006 09:22 PM
i think a nice granite grey would be a neat contrast...
and that way it's kinda an interpretation of the orig.
this project really does look amazing!!!!
what script are you going to put under the ducktail?
carrera RS ?
Carrera 3.2
3.2 RS
911 RS ?
let us know!!!
ericwitte 12-03-2006 02:45 PM
updates
installed the engine yesterday and some lightweight sound deadening/heat shieldiing on inside firewall..today began the rs carpetinghttp://forums.pelicanparts.com/uploa...1165185483.jpg http://[img]http://forums.pelicanpar...1165185802.jpg http://forums.pelicanparts.com/uploa...1165185825.jpg http://forums.pelicanparts.com/uploa...1165185843.jpg
ericwitte 12-03-2006 02:47 PM
http://forums.pelicanparts.com/uploa...1165185984.jpg http://forums.pelicanparts.com/uploa...1165186014.jpg http://forums.pelicanparts.com/uploa...1165186044.jpg
mjshira 12-03-2006 02:49 PM
looks outstanding. nice job.
mjshira 12-03-2006 02:50 PM
man do I wish they made SSI's for a built 3.6!!! so-o many more exhaust options.
Adam 12-03-2006 03:10 PM
Whoa! Superb job!
randywebb 12-03-2006 04:40 PM
What is the lightweight sound deadening/heat shielding that you used?
SteveM911 12-04-2006 02:10 AM
Looking Good, well done,
Can't wait to see the finished article.
ericwitte 12-19-2006 04:06 PM
rs door panels with a twist, instead of leather strap/fiat handle, we welded window crank h/w into door actuator ,attached window crank..acts as handle and lever...eventually cranks will be modified and black wrinkle p/c'd or will fab something out of aluminum, also Mike fabbed and welded b-pillar attachement onto safety devices cage, to be bolted thru with stock shoulder belt attached for street rs plush carpet installed all sound deadening etc manufactured by caehttp://forums.pelicanparts.com/uploa...1166573171.jpg http://forums.pelicanparts.com/uploa...1166573187.jpg http://forums.pelicanparts.com/uploa...1166573215.jpg
ericwitte 12-19-2006 04:08 PM
http://forums.pelicanparts.com/uploa...1166573263.jpg http://forums.pelicanparts.com/uploa...1166573276.jpg http://forums.pelicanparts.com/uploa...1166573296.jpg
Mysterytrain 12-19-2006 05:56 PM
ok, eric this has been really bothering me...dude, you need to paint that fuel tank! I'm in New Jersey I can swing by with a rattle can..let me know. I can't sleep worrying about this.
ericwitte 12-19-2006 06:21 PM
too funny, Ron! Actually, I cleaned it up after I purchased, back to original finish after much lacquer thinner and brain cells...nothing to do about the tire discoloration..the tank looks great in person (lots of dust on it in the pic as well). and you will not see the tire ring when the spare is in place
lateapex911 12-20-2006 07:15 AM
Man, it's looking good! When can I come over and see it? I can be there in 10 minutes, just give me the high sign!
Not sure about the script color...or even if you need it at all. maybe silver?
ericwitte 12-20-2006 07:35 AM
Jake,
Thinking of grey, black or white script. Was considering silver, but decided it was too bling against the bright blue. Eventually will finish the fuchs with rsr look, but for now ? Pm me your phone..I will call you next time I am working on her
lateapex911 12-20-2006 09:52 AM
PM on the way..
I have silver on my racecar (Mazdaspped), and it looks OK. Not the chromy type, THAT would be bling...yeccch.
ericwitte 04-08-2007 05:16 PM
update v close to completion...a quick peek at rear f/g bumper and mk exhaust, jet hot coated..the clear indicators will have clear bulbs and serve as my reverse lights...figure I can always replace with stock reflectors later, if I come up with a better idea clear coat is all buffed out, wiring done..we should start up next weekend :) :) :) :) :) :) http://forums.pelicanparts.com/uploa...1176077776.jpg
