PRO Motorsports
Ever wonder what your drivetrain weighs?
The LF is the starter, the RF is the mag case 915 non-lsd trans, and the two rears are the engine with clutch and flywheel and complete intake and exhaust. My short-stroke 2.5 with MFI.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
for clarification...
the picture is hard for me to read do the RF and RR say: 101/198? thanks brant
914/6 2.0S with twin plug all metal body panels 19quarts of oil 4 gallons of gas and 1826 lbs (wet) |
This should help
Neil '73 911S targa |
PRO Motorsports
Yes. The starter weighs 15#, the trans weighs 101# (dry) and the complete engine with clutch and flywheel weigh 391# If you subtract 25# for the heavy stock muffler, and 25# for the clutch/flywheel, that's a 341# complete 911 engine! I wonder what a VW type-IV motor weighs. Probably not much less.
Tyson,
So ... how did you manage to lose 18 lbs off the 915??? It is listed at 119 lbs in the '72 - '73 spec book ... or, maybe that figure was for the 915/06 with oil pump and squirter system??? OK, now I remember ... full of oil, and starter was mounted to the 915!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-01-2006 at 02:05 PM.. |
PRO Motorsports
Warren, I bet they included the starter in that figure. Then there's the weight of the oil.
Maybe Tangerina has had Lipo since moving into LA...
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Stressed Member
Any details on the 2.5 short stroke w/MFI? I tried searching but all I got was short shift kits...
-------------------- Garth 70 911E 08 Buell XB12XT |
PRO Motorsports
I used a '77 7R case, shuffle-pinned and line-bored back to standard. 2.2S crank and rods. JE pistons, 90mm. 10/1 CR. S cams and ports. Early rocker arms. (early rockers are forged, so they are lighter than the cast, and they have a slightly higher rocker ratio.) Fully balanced, etc. I have the rev limit at 7300, but the motor will handle 8300 with some racing springs and retainers.
so these numbers are no where near as accurate as yours... but the numbers we have been throwing around forever were: type IV motor 250lbs type 914(901) trans 75lbs and -6 early motors 400lbs. seems that your experiments somewhat validates the 400 figure. with flywheel your talking about 366... so maybe the 400 figure was with mufler and all included... (do you agree that my aluminum block would be roughly +20lbs? or 388lbs?) (I can't tell you if the 250 figure did or did not include all those components) awesome... thanks again. brant
PRO Motorsports
Brant, the mag case saved 24# over the sandcast aluminum case. Then from there, it all depends on what cylinders you have, chainboxes, cam covers, etc.
I'm running Nikasil 90mm cylinders that weigh 15# (All 6 together) less than the cast iron, and 12.5# less than the biral.
Tyson,
will you do me a favor? will you guess-timate my motor weight for me, compaired to a mag case motor like yours?..... (I had always thought my motor was around 20lbs extra compaired to a mag motor, but never even thought about the weight of the cylinders, chainboxes, or cam covers..... now I'm thinking my motor is probably closer to 40lbs extra instead of 20) here is my motor: 1966 aluminum sand cast block with 1966 chainboxes and cam covers. And stock 1967S pistons, cylinders, counterweighted crank, rockers, cams, IDS carbs, etc... (basically a stock 67S motor) (oh.. it probably makes no difference, but a 2.7 oil pump and 2.2 rods) If your motor is 341lbs and you add the aluminum parts on mine what do you think it would weigh in at without the flywheel/clutch? thanks for your time sir! (sorry for the tedious question but I get off on this weight stuff) brant
drag racing the short bus
The Terror of Tiny Town |
dd74
there may or may not be a difference between the 3.0 aluminum complete.. and the early 2.0 aluminum complete. I think the casting method was different so maybe?... plus, I've shipped about 3 motors myself and think the packaging and crating technique could cause a 30lb difference right there depending on the type of wood and structure. So really interested in the input of motor only. I had always heard 20 also, but I trust tyson and just plain want to hear another data point to see if it confirms it or differs. Brant (who is wondering if he could get his metal racecar down to 1810 wet with a mag -6?)
Crotchety Old Bastard
A fully dressed California spec '78 930 engine weighs 529 pounds - ALONE.
Add-ons can pack on the weight in a hurry!
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
bump to get more input
PRO Motorsports
Yes, there is a difference between the early sand-cast aluminum case and the 930 case that all 3.0/3.2 cars use. The early sandcast is a just a tad heavier.
The Factory claimed 24# weight savings going with mag over the sand-cast aluminum. To answer Brant's question, you can add: 24# case 7# chainhousings/covers 0# cam covers (mine are Carrera aluminum, so no difference) 12.5# cast iron lined cylinders Total 43.5 Now you can subtract roughly 12# for carbs versus MFI So: 43.5-12.5= 31# So you're in the 370# neighborhood, without clutch/flywheel or muffler. The reason I left off the muffler weight in my previous post is that many people run megaphones at the track, saving 20# of muffler weight.
Thx Tyson -- do you have oil pump wt. data over the years?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Thanks Tyson...
love the info.. love the thread.. love this board... brant
