Best spark plugs to use? Hi-tec or Standard?
'87 Carrera - I'm currently using ND Iridium plugs and feel they don't seem to perform as well as the Bosch Platinum Plus (two ground electrode) plugs I was using. These exotic plugs advertise a lower voltage requirement to fire and I think this has some implications on performance.
First, since they will fire at a lower voltage wouldn't that mean the spark may be happening slightly sooner resulting in a slightly advanced timing? Second, wouldn't that also mean the spark is less intense due to it happening at a lower voltage or less time for voltage buildup? I just have a suspicion these plugs are meant more for longevity and emmissions compliance than any thing else, and the advertising for performance improvement is hype. Thirdly, I guess these plugs would stress the ignition components less resulting in longer lived components. It would seem the best performance plug would be a standard resister type, Bosch or NGK. This may tax the ignition components more but the reward is a more intense spark. The nonresister type would probably produce a less intense spark. Thoughts or expertise appreciated. Thanks. |
Your guesses sound logical. I don't have any experience using the exotic plugs. One suggestion is to hook one up off of one wire and observe the spark in the dark versus the spark in the dark of a standard new one (like checking for spark) with the fuel pump fuse removed.
I believe the opinion of many is that the standard copper plugs (NGK or Bosch) are best for the Carrera. I switched back from the Bosch Platinums and haven't looked back.
putting anything non german on or in a german car ..................well just aint right!
Mike |
I've always had the best luck with the bosch copper, seem to run the most consistently on my more or less stock 3.0
I like NGK BPR6EY ES is the standard, EY is the V Power
Both NGK and Bosch make excellent plugs.... and each has a premium range that might include a copper or silver core for wider heat range...good.
The multi-prong plugs simply extend the running time of the plug. As a spark is created, it will jump from the center electrode to ONE of the side electrodes ( typ. closest-one). As that side-electrode wears, the next spark will likely jump to ANOTHER side electrode and stay there for a while...and the cycle continues. It would be rare ( impossible?) for a spark to jump simultaneously to two outboard prongs..... The Bosch Copper, Bosch Silver, and various NGK's ( with their nice rolled threads too !) ...are all one needs to know !! - Wil |
Let's see if this works...
If you want to spec your NGK plug, you can use this; http://forums.pelicanparts.com/uploa...1141658436.gif You'll notice that there is a wide variety of plugs that can be used on the 911. |
Go with a standard copper plug . I had Bosch platinum 4's in my 3.2
and I thought it ran wel... After reading some comments on this board I decided to pull the plugs and take a look. They were fouled / carboned up pretty bad. Switched to NGK copper and it runs better than ever. The reason for the plugs fouling the way I understand it is that a air cooled engine needs a plug with a wider heat range V.S the more controlled conditions of a water cooled engine. The copper plugs have a wider operating range. I do continue to run the platinums in my BMW and the wifes Jeep though. Mike |
On stock engines use stock recommended plugs. The porsche engineers have determined and experimented for you by testing the heck out of all plugs you can use. The smae with tires and all suspension components.
NKG's get many votes here, reminds me to order some.
Q-1: Is it okay to use the spark plug remover tool in the car's tool kit? Q-2: Best way to pull the wires off? |
The tool kit spark plug remover tool is the only one I know of which can get the job done. It's tight in there!
I just gently wiggle the wire and pull it off. |
I put some NGK iridium plugs in my 3.2. It runs better than it did, but who knows how miles were on the plugs when I bought it. They did all look like the motor was fueling properly though :)
http://www.ngk.com/results_app.asp?AAIA=1262708 |
Thanks for all the answers everyone.
Looking at that last link to the NKG website, I'm thinking based on prices alone you would be better off changing basic plugs every 3,000 than replacing the top of the line plugs every 6,000 miles. Just my perception, not based on any facts or testing that I know of.:) |
Factoid..."jiggling" tight spark plug wires is a no-no.( i.e....a rocking motion back and forth) It opens up the gap on the connector...you need this be tight for the next plug that goes in. So yes...twist a stuck wire...then pull out as straight as you can... once the twist loosened it up.
- Wil |
This might be a good time to review a horror story I read about in Pelican less than a year ago.
Dude was removing plugs, the little metal "screw-on" end cap fell into the hole. What the heck is that end cap for, and how do you keep it from making a mess of things? |
Lore has it that w see these goofy screw-on end caps for plugs because some ancient cars actually had metal "o" rings on the end of the plug wires that screwed on.
The caps were added to accommodate the vast majority of "normal" cars that use snap-in end connectors.... Crazy, huh ?...especially since these guys love to get loose and come off...and at the wrong time too ! - Wil |
Voltage / Spark Intensity
The lower the voltage requirement of a plug, the less intense the spark will be. On high compression engines, you need a more intense spark than on a lower compression engine. The air gap between the center elecrode and the ground electrode is the highest point of resistance. If you reduce the gap, you reduce the voltage necesarry for a spark to jump the gap. If you increase the gap, you increase the voltage requirement. Heat Range Selecting the proper heat range for your plug is also very important, as a plug performs best in the range it was designed for. It is also one of the harder balancing acts. Many people think the plug is only there to ignite the F/A mix, and do not understand that the plug is designed to also help remove heat from the combustion chamber. The "heat range" noted on plugs is not the operating environment they are designed for (IE: do not use HOT plugs in a HOT engine) but are instead a statement of their ability to remove heat from the engine. So if you have a hot-rodded engine that is developing hotter head temps than stock, you will need to go to a slightly colder plug. Similarly, if your engine will be run at high RPM for long periods of time, you will need a slightly colder plug. Also, a spark plug's heat range has no relationship to the actual voltage transferred though the spark plug. However, overheated plugs can crack and drop debris in the cylinder... not good. Also an overheated plug is a "hot-spot" in the cylinder that can lead to damaging pre-detonation. If you do not have oil seepage into the cylinder, fouling is often an indicator that your plug is not acheiving it's optimum operating temperature. This can be corrected by moving to a hotter plug. |
So, increasing the gap from say, 0.28" to 0.30" may increase spark intensity? Based on the logic of increased resisitance equals more intense spark, the resisitor type plugs are the way to go?
The resistance that increases the spark strength is the gap only. A resistor plug will not do anything to increase spark strength. What the iridium folks say is that since the plug requires less voltage to fire, they can run a bigger gap. A balancing act of sorts that gives a very strong spark. Both NGK and Denso advertise their iridium plugs as their "high end high performance" plug. Plus they last longer and retain their performance characteristics longer - much longer than other plugs because the iridium metal is very hard.
I thought that the heat range for a plug was it's ability to dissipate it's own heat, not to remove heat from the engine.
But, much of the popular opinion on this site says a standard low tech plug is best for performance vs. what the new iridium plug's advertise. Maybe installing the iridiums with a slight increase in gap is the way to go?
I see lots of talk about dual-plug heads too. I guess to each their own. If you go to their site, it will say be very careful about gapping iridium plugs because you can break the electrode very easy. I have not checked but they might come with a slightly larger gap from the factory.
Dual plug heads really serve an unrelated purpose.... they are so that the combustion mixture is ignited from two points for a more even and more complete burn. It also results in a faster burn, meaning that less timing advance is necessary. These features can be especially helpful when using big cams and/or forced induction. |
I agree that it might be a matter of perspective. Granted anything that sticks out of the side of an engine dissipates heat (sensors, plugs, brackets, etc.), I just find it really hard to believe that engineers would design spark plugs as a means of cooling off an engine. If so, we'd have these huge, vaned contraptions controlling our sparks.
From the Bosch site: The so called “heat range”, which is assigned to each spark plug, is used to characterize these heat dissipation capacities. A plug with a low heat range number (e.g., 2-4) indicates a cold plug that quickly dissipates heat to the engine block and cooling system, while a high code (e.g., 7-10) indicates a hot plug that retains heat. By properly selecting the heat range of the plug, it ensures that the plug will operate between the plug’s designed operating range of 500-900 degrees Celsius. In this range, the spark plug will be self-cleaning, yet will not be hot enough to pre-ignite the air/fuel mixture. All in all, I agree with the NGK and Denso quotes but I think all the unwanted thermal energy is directed at the plug and more importantly, the plug tip and not the engine itself. |
Here's some info from Champion that proves your point:
The spark plug can help maintain the optimum combustion chamber temperature. The primary method used to do this is by altering the internal length of the core nose, in addition, the alloy compositions in the electrodes can be changed. |
My turn:
From Wikipedia: http://en.wikipedia.org/wiki/Spark_plugs Heat from the combustion chamber escapes through the exhaust gases, the side walls of the cylinder and the spark plug itself. The heat range of a spark plug has only a minute effect on combustion chamber and overall engine temperature. A cold plug will not materially cool down an engine's running temperature. (Too hot of a plug may, however, indirectly lead to a runaway pre-ignition condition that can increase engine temperature.) Rather, the main effect of a "hot" or "cold" plug is to affect the temperature of the tip of the spark plug |
In late but go NGK copper. Very high quality boom for the buck plus phenomenal heat range!
87 blk coupe ;) |
[QUOTE]Originally posted by cashflyer
[B]Voltage / Spark Intensity The lower the voltage requirement of a plug, the less intense the spark will be. On high compression engines, you need a more intense spark than on a lower compression engine. Total agreement, see my posts on the problems with my supercharged engine and high rpm misfiring. When I changed to Denso iridium I got clean 7000 RPM pulls with no misfiring and 7500 miles later still perfect. Not dogma just real world fact. Also Amsoil is great. Best regards, |
I just removed the Bosch platinum W5DPO plugs from my 1977 2.7L. I have never seen more carbon on any plug - ever. With 6,000 miles on them they looked like they had been in since 1977.:eek:
I put some NKG BP7ES plugs in, changed the rotor and distributor cap. I still need to do the timing but a huge improvement already. At $2.16 a plug I'm going to change the plugs every year.:) |
I agree.
I have a 71' 911E with MFI. I pulled my "fancy" and expensive plugs yesterday and after 16 months, they're black. Since MFI cars run rich even when dialed in properly, I'm just going to clean these fancy plugs now and replace them in a few weeks with the NKG's and probably replace them every year or two. Gavin |
I just replaced my 930's plugs with stock ones, being that they are a very cold plug and Im in Arizona heat, I think its best. Anyone know of a better 930 plug than stock?
Is it possible to run one step cooler on a USA 3.2 during D/E's or hot days? I'm running BPR7EIX (NGK), which is one step cooler than the 6.
j.p. |
In another plug thread, John Walker seems to sing the praises for the Denso irridiums for the carbuerated engines, keeping fouling to a minimum. I recently invested in the Denso irridiums on an SC and seemed very pleased. My gas mileage has improved.
There are so many variables from engine to engine. From my experience, my engine (78') has the lower compression so the seemingly less intense spark of the irridiums work well. I experimented with Bosch platinums and NGKs. It seemed to run more efficiently with a slightly less gap than recommended but tolerated less timing changes. I feel very happy with the Densos. |
NGK or Bosch copper cores - the cheap ones. I have had nothing but problems with Beru Silverstones, Bosch Platinums, etc- any precious metals whatsoever. To give you an example, I put a set of Silverstones in my 1883cc 616 engine and it didn't feel right, was missing occassionally. Pull the plugs, we found the center electrode, not the prong, had fallen over and was in contact with the insulators. Put a set of Bosch copper cores on and it runs fine now. Not to mention, there as a 20hp difference on the dyno, but I think that's because the silver ones were not firing worth a damn.
