Best spark plugs to use? Hi-tec or Standard?
'87 Carrera - I'm currently using ND Iridium plugs and feel they don't seem to perform as well as the Bosch Platinum Plus (two ground electrode) plugs I was using. These exotic plugs advertise a lower voltage requirement to fire and I think this has some implications on performance.
First, since they will fire at a lower voltage wouldn't that mean the spark may be happening slightly sooner resulting in a slightly advanced timing?
Second, wouldn't that also mean the spark is less intense due to it happening at a lower voltage or less time for voltage buildup?
I just have a suspicion these plugs are meant more for longevity and emmissions compliance than any thing else, and the advertising for performance improvement is hype.
Thirdly, I guess these plugs would stress the ignition components less resulting in longer lived components.
It would seem the best performance plug would be a standard resister type, Bosch or NGK. This may tax the ignition components more but the reward is a more intense spark. The nonresister type would probably produce a less intense spark.
Thoughts or expertise appreciated.
Thanks.
Old 03-05-2006, 12:09 PM
Your guesses sound logical. I don't have any experience using the exotic plugs. One suggestion is to hook one up off of one wire and observe the spark in the dark versus the spark in the dark of a standard new one (like checking for spark) with the fuel pump fuse removed.
Old 03-05-2006, 01:03 PM
I believe the opinion of many is that the standard copper plugs (NGK or Bosch) are best for the Carrera. I switched back from the Bosch Platinums and haven't looked back.
Warren & Ron, may you rest in Peace.
Old 03-05-2006, 01:38 PM
charleskieffner's Avatar
putting anything non german on or in a german car ..................well just aint right!
Old 03-05-2006, 05:14 PM
IROC's Avatar
Having said that...I have found that NGK makes some pretty good plugs. I am currently using NGK BPR8ES plugs in my 10.3:1 3.2 and they are performing wonderfully. I used NGK BP7ES plugs in my 2.7 for years and they were great too.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 03-05-2006, 05:35 PM
Friend of Warren
Just keep telling yourself that. Anway, all I have ever used is NGK.
Kurt V
Old 03-05-2006, 05:40 PM
petrolblue83911's Avatar
I've always had the best luck with the bosch copper, seem to run the most consistently on my more or less stock 3.0
Old 03-05-2006, 06:40 PM
911longhorn's Avatar
I like NGK BPR6EY ES is the standard, EY is the V Power
1989 Carrera
Hookem Horns!
Old 03-05-2006, 07:10 PM
Both NGK and Bosch make excellent plugs.... and each has a premium range that might include a copper or silver core for wider heat range...good.
The multi-prong plugs simply extend the running time of the plug. As a spark is created, it will jump from the center electrode to ONE of the side electrodes ( typ. closest-one). As that side-electrode wears, the next spark will likely jump to ANOTHER side electrode and stay there for a while...and the cycle continues. It would be rare ( impossible?) for a spark to jump simultaneously to two outboard prongs.....
The Bosch Copper, Bosch Silver, and various NGK's ( with their nice rolled threads too !) ...are all one needs to know !!
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-06-2006, 05:27 AM
Let's see if this works...
If you want to spec your NGK plug, you can use this;
You'll notice that there is a wide variety of plugs that can be used on the 911.
Old 03-06-2006, 07:22 AM
Go with a standard copper plug . I had Bosch platinum 4's in my 3.2
and I thought it ran wel... After reading some comments on this board
I decided to pull the plugs and take a look. They were fouled / carboned up pretty bad. Switched to NGK copper and it runs better than ever. The reason for the plugs fouling the way I understand it is that a air cooled
engine needs a plug with a wider heat range V.S the more controlled conditions of a water cooled engine. The copper plugs have a wider operating range. I do continue to run the platinums in my BMW and the wifes Jeep though.
Mike
1985 Carrera
1995 325is
2000 Grand Cherokee
Old 03-06-2006, 09:42 AM
On stock engines use stock recommended plugs. The porsche engineers have determined and experimented for you by testing the heck out of all plugs you can use. The smae with tires and all suspension components.
Old 03-06-2006, 10:40 AM
NKG's get many votes here, reminds me to order some.
Q-1:
Is it okay to use the spark plug remover tool in the car's tool kit?
Q-2:
Best way to pull the wires off?
Old 03-06-2006, 11:04 AM
The tool kit spark plug remover tool is the only one I know of which can get the job done. It's tight in there!
I just gently wiggle the wire and pull it off.
Ben Fegan
1988 Carrera Targa
Old 03-06-2006, 11:20 AM
Friend of Warren
Q-2:
Grab connecter, twist, pull.
Kurt V
Old 03-06-2006, 11:22 AM
heiliges blechle!
I put some NGK iridium plugs in my 3.2. It runs better than it did, but who knows how miles were on the plugs when I bought it. They did all look like the motor was fueling properly though
http://www.ngk.com/results_app.asp?AAIA=1262708
'84 M491 '07 Silverado
'75 Suzuki GT550 2-stroke triple
'02 Aprilia Mille R '07 Ducati S4Rs '08 Night Train
Old 03-06-2006, 11:37 AM
Thanks for all the answers everyone.
Looking at that last link to the NKG website, I'm thinking based on prices alone you would be better off changing basic plugs every 3,000 than replacing the top of the line plugs every 6,000 miles.
Just my perception, not based on any facts or testing that I know of.
Old 03-06-2006, 11:56 AM
Factoid..."jiggling" tight spark plug wires is a no-no.( i.e....a rocking motion back and forth) It opens up the gap on the connector...you need this be tight for the next plug that goes in. So yes...twist a stuck wire...then pull out as straight as you can... once the twist loosened it up.
- Wil
Wil Ferch
Old 03-06-2006, 01:06 PM
This might be a good time to review a horror story I read about in Pelican less than a year ago.
Dude was removing plugs, the little metal "screw-on" end cap fell into the hole.
What the heck is that end cap for, and how do you keep it from making a mess of things?
Old 03-06-2006, 01:23 PM
jeff1hughes's Avatar
This is a good arguement though...believe it or not, technoloy has advanced a little bit in the last 20 years or so. That said, I only use standard plugs in the Porsche, it runs better on them.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 03-06-2006, 09:41 PM
