Can injectors get plugged?
Howdy, 77 2.7 with CIS. Doesn't seem like it's running on all 6, but not a spark problem. Do/can injectors get plugged?
Old 03-09-2006, 07:36 PM
Detached Member
Hugh R's Avatar
Absolutely!! Don't know anything about your car, but try a can of Chevron Techron, accept no alternatives! Then drive the crap out of it.
Hugh
Old 03-09-2006, 07:46 PM
Had a plugged fuel injector, ran a can of techron through it, Fixed the poblem. Now every oil change I run a bottle of techron through the system, then change oil
Old 03-09-2006, 08:08 PM
ThePointman's Avatar
Send a message via ICQ to ThePointman
Can you buy the can O Techron at any Chevron? Anyone know if it is available in Canada? I take it that Techron is a fuel additive? If it is a fuel additive what does it do exactly?
Old 03-09-2006, 08:14 PM
Adrenaline Junkie
Hayabusa's Avatar
I highly recommend 'Redline' Injector Cleaner!!!
Old 03-09-2006, 08:15 PM
Detached Member
Hugh R's Avatar
Try the chain auto parts stores, cheaper than at Chevron by a lot. Its not an additive, its an injector cleaner.
Hugh
Old 03-09-2006, 08:21 PM
I second that. Never buy Techron at the Chevron station.......way, way too much $$. Go to PepBoys. I buy mine in cases at Costco. Not sure if it is actually cheaper at Costco since whenever I go to Costco you tend to ignore your budget
For example, "Honey, I am buying eggs, bacon and milk at Costo." 2 hours later you come home with mdse worth $400.00 heh heh heh
Old 03-09-2006, 11:14 PM
planeguy67's Avatar
Of course, if you buy gas at Chevron, it comes with Techron already in it for free.
Proud Owner:
1996 C2 Cabriolet (993)
1988 944 SOHC
1998 Ford Ranger XLT (Total P.O.S.)
2005 Specialized Allez Comp 27-speed (yes, it's a bicycle!)
My Porsche page (I know, kinda lame. Just wait until I learn Dreamweaver)
http://members.cox.net/kronowit/porschepage.html
Old 03-10-2006, 10:24 AM
Large Registered Member
PatrickB's Avatar
Sometimes a $10 bottle of miracle juice isn't going to cut it...
Don't discount the possibility that your almost 30 year old injectors might have exceeded their useful life...
After chasing an intermittent rough running problem on my 3.2 for nearly 2 years, it turned out to be a couple of bad injectors. I replaced just about everything except the injectors prior... With a new set of injectors, the car has never run better with a 140k miles and counting...
'85 Carrera Coupe, Marble Grey #118 JP/R6
'93 Lexus SC400, '00 Ford F-150
'70 911T- 2.7 (SOLD)
Old 03-10-2006, 11:31 AM
Semper drive!
rcecale's Avatar
A couple of us Pelicans were discussing this just yesterday. Technical Service Bulletin 2510, released December 6, 1985 says:
"Partially restricted fuel injectors can be cleaned through the following procedure and material:
1. Fill up fuel tank
2. Pour 20 ounces of "Techron" into the fuel tank.
Note: Techron is marketed by Chevron
3. The car should be driven until the fuel tank is half empty.
4. Refill the fuel tank.
5. This procedure, as outlined from points 1 to 4 should then be repeated 2 additional times.
6. To keep injectors clean, we recommend adding 20 ounces of Techron after 5 fuel tank refills. However, never more than 20 ounces per 3,000 miles."
'nuff said!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 03-10-2006, 05:30 PM
