PorPete's Avatar
Send a message via Yahoo to PorPete
POP QUIZ! Name that part!
What is it? I can't firgure out what is that red capped thingis... It's on the rear part of my 77 3.0 engine, just above the clutch, under the air box. Should I replace it since I am here? Brown / white wire.
Pete
Fredericksburg VA USA
74 EURO Carrera (right hand drive)
82 Targa (left hand drive)
Old 03-09-2006, 05:14 PM
Weaver's Avatar
oil pressure warning light sensor. Its cheap and it will fail at some point.
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 03-09-2006, 05:17 PM
911scNorway's Avatar
Yes replace it, its an oil pressure switch and while you are there replace the O ring on the internal oil thermostat, its the oval shaped flange with 2 nuts just behind the "red thing" in your picture.
Mark
996 C4
911 SC ex
An Englishman in Norway (yes itīs cold)
Old 03-09-2006, 05:23 PM
PorPete's Avatar
Thank you so much guys... I was pulling my hair out.
Thank you!
Pete
Old 03-09-2006, 05:25 PM
