POP QUIZ! Name that part!
What is it? I can't firgure out what is that red capped thingis... It's on the rear part of my 77 3.0 engine, just above the clutch, under the air box. Should I replace it since I am here? Brown / white wire.
Pete Fredericksburg VA USA 74 EURO Carrera (right hand drive) 82 Targa (left hand drive) |
oil pressure warning light sensor. Its cheap and it will fail at some point.
Weaver '88 911 Targa '03 911 Turbo, X73 Susp. '13 Panamera GTS PCA member Central Indiana |
Yes replace it, its an oil pressure switch and while you are there replace the O ring on the internal oil thermostat, its the oval shaped flange with 2 nuts just behind the "red thing" in your picture.
Mark 996 C4 911 SC ex An Englishman in Norway (yes itīs cold) |
Thank you so much guys... I was pulling my hair out.
Thank you!
Thread Tools | |
Rate This Thread | |
