goldsc78258's Avatar
Send a message via Yahoo to goldsc78258
3.2 engine change
I just got a chance to get my hands on a 1974 recked car with a 3.2 liter engine and I was thinking on transplanting that to my autoX car wich has a 2.7 right now.
Here is My question to you guys that have done this is there a lot of work involve in this change? any chassis or body mods? How about engine harness change? anything I should be aware of on 3.2l engine any major flaws? All necessary hardware should be there as it is in a 74, all input will be helpfull for me to make a decission as ar as what to do
Thanks in advance
Old 03-10-2006, 03:49 AM
Jim Smolka's Avatar
There is a bunch of information on 3.2 conversions in previous postings.
To answer the questions,
It is a bunch of work. Besides swaping the motors, notching the 915 gearbox housing, and the electrical work, it is not a bad project. You will need an oil cooling system. Be sure to get the DME engine harness, coil, tach, DME,
The 3.2 motor is a great motor, but it is now ~20 years old. Time for some maintenance to insure that it will work well. Some 3.2 have valve guide issues.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-10-2006, 04:23 AM
Doug&Julie's Avatar
A lot of info here: http://www.pelicanparts.com/MotorCity/marcesq1/
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 03-10-2006, 04:44 AM
All 3.2's with stock rod bolts have rod bolt issues if you are going to run at high RPM.
Bryan
what would it take timewise any idea? anybody done it yet?
Thanks for the responses they have helped a lot
Old 03-10-2006, 05:03 AM
Ben M's Avatar
I have a 3.2 in my 72. It's a lot of work, but worth it. The engine will fit in just fine except for notching the bell housing, so not much more time than normal. The electrical part will have you swearing in German and consumption of beer is advised. I would figure 10 hours on the electrical side of things. You also have to install a return gas line and provide oil cooling. The front cooler cost gets expensive due to the cost of the oil lines. I used an Earl cooler, that was maybe $250.00. I've attached an electrical chart that will speed things up a bit.
Go for it!
Old 03-10-2006, 06:01 AM
Porsche-pa
75Carrera's Avatar
Porsche Crest 3.2 installed
Here's a few shots of the '86 3.2 I put in my 75 Carrera. It's a great upgrade and not overwhelmingly difficult. This is the 28 bar oil cooler I used. There are lots of threads that provide everything you should need. Best of luck, you'll be amazed!
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 03-10-2006, 06:21 AM
You should already have the return fuel line since you have CIS and your front trombone oil cooler will do the job.
Joe
74 w/ 86 3.2, trombone cooler
Old 03-10-2006, 10:41 AM
Thanks guys I think I'm goign to do it
I'll keep you updated
Fred
Old 03-10-2006, 10:54 AM
Porsche fanatic
jager911's Avatar
As others have said, you need the DME relay, CPU and the harness, remap the pins on the wiring harness, there are only 5 essential wires needed. I carefully notched the bell housing for the flywheel/timing sensor using a jig saw. You'll be amazed at the torque. I also had Patrick Motorsports take a stock '74 muffler, weld up the opening and add 2 straight pipes to create a sport muffler. With headers, it adds noticeable power. You'll also have to bend 1 or 2 fuel lines to connect the fuel filter and the fuel return. I kept my '74 fuel pump as the 3.2 has built-in fuel regulators so no need to change your fuel pump assuming you have CIS now with your 2.7. Good time to add alum PP. If I recall, I had to run power from the ignition switch to the CPU. It's a great motor and easier to do than a 3.6.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 03-10-2006, 07:55 PM
