Is an engine swap a lot easier with carbs vs CIS/MFI etc ?
I am playing with the idea of getting an older, pre-smog, car for fun and track use. I have seen some threads about installing the 3.2 engine in a car like a '74 and it's not too bad, but still.
So, if I were to go the route of carbs, how much easier would the overall process go?
Also, can you carb a larger engine, such as the 3.6L?
trying to think before jumping this time
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 03-10-2006, 03:42 PM
bigchillcar's Avatar
chris, you know how this is supposed to play out...with p-cars, there's no 'jumping' only 'diving in'! or sliding down the slippery slope, too, i suppose.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 03-10-2006, 03:48 PM
I know, but I keep losing money doing that
Probably dreaming here, but the hot rod urge sure is pulling me lately....
I am pretty sure I'd have to give up my '87 to get it done too.
-Chris
1998 CR500
Old 03-10-2006, 04:33 PM
Doug&Julie's Avatar
How much for the '87?
Seriously...you can carb a 3.6 if you want. You can carb pretty much any air cooled motor (I'm pretty sure). I think it would make it easier to transplant into an earlier car, but I'm not sure how much.
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 03-10-2006, 05:24 PM
Grady Clay's Avatar
Chris,
This is very dependent on the car, engine and what you want. You might look to a long-term project where you can keep the ’87. As everyone will tell you, these projects can be done quickly – for a price. The most economical solution is to spread it out over time and be patent collecting the car(s) and parts when the opportunity arises.
Being willing and able to buy and sell allows you to collect what you need and pass on the rest to someone else who is in need. The “food chain” so to speak.
Last week I was advising a local Pelican on his rehab-refurbish project. He will need 2-4 donor cars and lots more. I saw a 10+ year project.
You can do that with the ’74-’77 or ’78-’83 911s. Now that you are up in Marin/Sonoma, do you have the storage space?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-10-2006, 05:58 PM
Todd Simpson's Avatar
If your goal is an easy swap then stick with the stock induction for your chosen motor. Carbs have advantages but make for some additional complications too.
I like a 3.2 in an early car. It's the first use of DME on a 911 motor and makes for quick starts and good driveability. 3.6 is very nice too but takes more effort due to sheetmetal, exhaust and other mods needed.
Old 03-10-2006, 07:24 PM
RideShoot&Drink's Avatar
Send a message via Yahoo to RideShoot&Drink
Hey Chris, when I was buying my mutant, I was first thinking about having 3.6 in there, but was told that it's much easier to have Turbo or SC motor installed. Reason for that being...fuel system (CIS), no need to update harness, DME, heat and some other things that I don't even remember now. As far as I understand Turbo just gets dropped there with proper clutch to 915 and additional fuel pump. Same probably applies to SC engine. Thus, you see much more early/mid year cars/SC engine combos than, early car/3.6. Lotsa nice early cars with 3.6's, but it's more expansive to get there...ah after all, it's just money. It'd be very cool to have an early car with 3.6, should be fun. But, early car with Turbo should be fun as well! Good luck with your search!
I'm in heaven, when I drive my nine eleven...
Old 03-10-2006, 08:03 PM
