P Car Addict
klober23's Avatar
Whats a good trany for my engine?
I am placing my '81 911 SC 3.0 in my '78 911. Whats a good solid trany I can put in this?
RIP Grady Clay
Old 03-10-2006, 10:50 PM
Work in Progress
Rich76_911s's Avatar
I think that you are essentially limited to the 915 transmission. You could go with a G50 but to do so would take major modifications to the body of your car (from what I understand). I am not an expert on the conversion to G50's all I know is that it takes a lot of work. I'll drop you a PM I might be able to help in the trans department.
One thing to note is that there was a change in case material from magnesium to aluminum, I believe. At least I know sometime around 1980 there was a change done to the transmission to give it more strength. I'd probably suggest you research and find out exactly what the strengthening was and find a trans with the added strength.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 03-10-2006, 11:33 PM
