Banned
Chain housing leaking, expensive fix?
Hey guys I tried searching but didnt find the answer I needed. I need to know if oil leaking from the left and right chain housings is an expensive fix or what. Thanks
I'll second that. Got a leak between chain housing and cam housing. I believe the gasket looks like a fiber washer.
10 dollar part, 10 hours job. $500 labor.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
RETIRED
Just did it on my 3.6.....I had the engine and trans out anyways for a 2nd gear fix.....bought a Pelican top end kit and redid ALL the seals. Dry as a baby's butt after a good diaper change....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Can you replace the chain housing gasket with the motor in the car, or does the motor need to be dropped out?
If its the chain housing cover gasket that is leaking its an relativly easy job that can be done with an partial engine drop (lower the rear of the engine).
If it leaks between the chain housing and engine case or the cam end seal, then its a tad more nasty...
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Thanks for the quick answer. Does the partial engine drop instructions on this site apply for a 965 and also a 993? Also, how many inches can you really lower the car in a partial drop?
