Nobody
bob tilton's Avatar
Polishing window frames? 68 different?
I just did a 1" test section on my window frame using 400, 600, 1000, 1500, 2000 grit sand paper and was impressed with the mirror like results - no more fine scratches. BUT I noticed that the frame must have some sort of clear coat protection because the outer areas got "foggy" unlike the area I sanded through - flashbacks from when I stripped one fuch. AND I was concerned about sanding through any chrome plating to raw metal. HOWEVER I do recall a few people telling me the 68 door frames are lighter due to the material. SO can someone shed some light in the subject for me?
Is the 68 door frame different from other model years? If I started with a rougher grade to wipe out some of the deeper scratches do I run the risk of going through any plating? I assume that much like polished fuchs a little bit more care will now be involved without the clearcoat. This might be thge excuse I need to scotch brite all the brightwork on the car .
Bob Tilton
www.werkcrew.com
Old 03-14-2006, 09:07 PM
CHILI's Avatar
Wow, I can't imagine trying to polish all of the trim. The Mother's or whatever would get all over the rubber, I would think.
I also can't imagine your car looking any better. Man, as for narrow bodies, wow! I love your car.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 03-14-2006, 09:20 PM
Stressed Member
Scott Clarke's Avatar
Bob-
The earlier cars had chrome plated brass frames, and later they were anodized aluminum. It sounds like yours are aluminum, so the results will be much like those for the Fuchs. There is a place that refinishes and re-anodizes the frames, but it ain't cheap. I think it is called Anobrite. Search for a recent thread on the subject. The Scotch Brite idea is interesting. That would be cheap, and might look great. In the name of science, I think you should give it a try (and post pics)!
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 03-14-2006, 09:43 PM
Nobody
bob tilton's Avatar
Thanks guys! Anodized aluminum makes sense. Guess I got another project ahead of me. Scott - do you know if the rear qtr windows are also anodized aluminum?
Bob Tilton
www.werkcrew.com
Old 03-14-2006, 11:20 PM
Classic's Avatar
Bob,
I've got a 69 Euro spec coupe and took my trim to a mate the does polishing for a living, and he said that it all was bright dipped aluminum.
Classic 1969 911T
Old 03-15-2006, 01:25 AM
Bright dipped aluminium is a term used to describe Anodising..
Reanodising is cheap enough, its the polishing which costs.
It needs to be very very good ( ie fine grit) to be worth while..
Kind regards
Old 03-15-2006, 02:00 AM
Stressed Member
Bob-
Yes, if the door frames are bight-dipped anodized aluminum then the quarter windows should be also. The appearance of the chrome finish is noticeably different from the anodized versions. Does anyone now if '68 was the first year for aluminum? Do '68 coupes have fixed front vent windows?
Old 03-15-2006, 07:55 AM
The ’68 production cars, both 911L and 912’s, were a transitions year, even more than most years. Technically, yes ’68’s have the aluminum trim as opposed to the chrome. The ’68’s still had the moveable vent wings with a black vinyl/rubber type cover on the latch.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 03-15-2006, 10:51 AM
