mark '87 930's Avatar
930 slant nose vs regular 930
Everywhere I've read, the slant nose has about 10% (30HP) more than a standard version of the 930.. Does anyone know or have a list of components that make up the 30HP difference?
1956 Chevy 3100
2009 Subaru Forester
2003 KX250 X2(I like my toys!!)
Old 03-16-2006, 11:02 AM
I believe the S (Sport) in the 930S designation is actually for the higher HP powerplant....and it may be higher than 30HP difference.
Larger intercooler
1 bar boost spring (?)
Free flow exhaust
Warren & Ron, may you rest in Peace.
Old 03-16-2006, 11:16 AM
Rick is right about the larger intercooler and exhaust but according to the Porsche PET cd, the wastegates are the same. They do list a different turbocharger for the S and LE versions. I think it is a K-27 11/11. I just got the turbo support bracket from Porsche from the 1989 930 LE(ROW) to use in the installation of a K-27 7200 turbo on my '88 and it is indeed different than the stock bracket used to support the 3DLZ turbo.
Old 03-16-2006, 01:13 PM
78P930's Avatar
OSI930, What is the part number for that bracket?
Pat
10 Ford Raptor
86 930
Old 03-16-2006, 03:31 PM
930.123.921.05
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 03-16-2006, 04:18 PM
Kirk911SC's Avatar
According to "Original Porsche 911" by Peter Morgan, the Turbo SE slant-nose has increased power from:
-higher lift cams
-revised exhaust system
-higher boost pressure
-larger intercooler
Kirk
- '00 Dodge Viper GTS - Steel Grey - Yep...a domestic.
- '87 930 - Guards Red - Sold
- '82 911SC - Grand Prix White - Gone
- '78 928 - Silver - Long gone
- '04 Subaru WRX wagon - Sold
Old 03-16-2006, 04:54 PM
The turbo LE(M148) optioned cars used a K-27 7006, not the 11/11 as I stated earlier. The PET cd does not show a difference in wastegates so I am not sure about increased boost, could be though because I can't find a detailed parts listing for the wastegate internals. I believe the M148 cars were rated at 330 hp as well.
Old 03-16-2006, 06:14 PM
Porschephd's Avatar
7006 is an 11/11. You were correct.
Stephen
94 3.6Turbo 6-speed AWD
Old 03-16-2006, 08:13 PM
Thanks Stephen. Do you know if the LE and S cars ran higher boost and used different cams? I have seen reference to "S" cams before.
Old 03-16-2006, 08:18 PM
Porschephd's Avatar
They used different cams, but the boost was the same level.
Stephen
Old 03-16-2006, 08:20 PM
Thanks again, Stephen.
Old 03-16-2006, 08:36 PM
Stephen,
I've never found a part number for the revised cams, although I've heard the cams used on these engines had higher lift. Do you know the part numbers? There seems to be nothing in PET.
JR
Old 03-17-2006, 04:54 AM
Porschephd's Avatar
I will have to dig them up. They were Groupe B cams. I am not sure of the number off the top of my head, but I will get it when I get to work.
Stephen
Old 03-17-2006, 04:59 AM
I'd bet there were differences between the Euro and US "S" cars.
Some digging suggests the "Recirculation Valve" was deleted as well.
Old 03-17-2006, 06:34 AM
I didn't think US slant noses had any performance enhancements over the regular bodies. Has anybody ever confirmed the upgrades on an actual non-modified car?
Chris
1986 930
1972 911S
1970 911E
Old 03-17-2006, 08:36 AM
Porschephd's Avatar
The slant option itself is not a performance option. The SE option was as well as the original S.
Stephen
Old 03-17-2006, 08:45 AM
Forced Induction Junkie
WERK I's Avatar
When I rebuilt my engine two years ago, it had the following factory mods:
K27-7006(11/11)
Special Turbo Mount Bracket
Special up tube
SC cams with adapter to drive turbo sump pump
Dual Out muffler-that looked really cheesie(split tips on each side)
Standard 930 IC
Standard Row Heat Exchangers
Standard Wastegate/Spring
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 03-17-2006, 09:17 AM
Porschephd's Avatar
Yes, both options could be ordered. I have only seen one like yours were it was actually optioned with both.
Stephen
Old 03-17-2006, 09:26 AM
Would it be feasible to see a 30hp with that combination on a regualr engine then?
1956 Chevy 3100
Old 03-17-2006, 09:37 AM
Porschephd's Avatar
Heck yes!!!
Stephen
Old 03-17-2006, 09:42 AM
