Media Blaster
Does anyone have experience and/or a recommendation for a stand alone media blaster for a home shop? Space is not an issue, but I do not want one that needs to be placed on a table. I am also interested in what size/capacity/cfm air compressor would be required to feed one, short of going to a large 240v shop type compressor. Any issues with siphon type system? Easily changeover from sand/glass to walnut shells? Minimum dimension for access door.
I have been using the large blasting unit available from Eastwood. It runs off my 6.5 HP compressor and does a great job with either glass bead or silicon carbide for cleaning up everything from suspension parts to piston tops. It is a suction blaster rather than a pressure blaster. Pressure blasters are supposed to have more blasting power but are more expensive and probably not needed for the home shop.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
I have a Harbor Freight blasting cabinet, and it's done very well for me:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=38440 I was using a siphon but it was driving me nuts, they clog easily, and it takes a ton of air to get it going. I switched to a pressure unit, this one: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34202 That being said I don't think I could do much blasing with a small compressor, I have a 90gallon 208V and it's just about right for sandblasting and running DA's and such. At any rate the equipment at $89 a piece is worth it for me, I retore all sorts of cars, and you should see what a cleaned up pair of heater boxes look like!
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I have the second HF unit mentioned by Scott. It's gets air from a 7 HP / 60 Gallon compressor. Highly recommend.
Warren & Ron, may you rest in Peace. |
Senior Member
Use a table model HF blast cabinet and it works fine, but wish I had a stand up model. I have a 6.5 hp compressor, 220v and it has no problem staying up with it, while my old 3 hp 110v unit would run forever trying to keep up.
Door size? What are you going to put in the box? How much money do you want to spend? Get the largest you have money and room for. You will appreciate it later! joeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
i got a benchtop blaster from tool america - there on ebay. it cost me around $150 with shipping. it's about 22x32x22 and is a good size for most parts, not big enough for wheels however. i use the aluminum oxide media to strip paint and rust and it works ok. the blast gun clogs easily and the hose/fittings are really cheap. the box is metal and is bolted together - i would seal the seams with caulk because the media does get out. i think the internal light is a must - when blasting there is a lot of dust and the window turns almost opaque in no time. the blaster is nice to have but for difficult parts i would send them out to a professional. i have a set of bbs basket weave magnesium wheel centers and there is no way i'm blasting them myself.
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
I would take them to the powder coater directly because he has something vested in the outcome. On second thought, maybe the PC'r can hide his mistakes. I don't know, I'd just look out for those. (I have some BBS one piece wheels) |
I took Scott's and Rick's advice and bought a pressure blast unit from Eastwood and adapted it to my blast cabinet. Works really well but the dead man valve for blasting is pretty cumbersome to manipulate into the tight spots.
Does anyone know of an alternative lighter weight presuure blast nozzle?
Hey Guys
Let see some work performed by the Blasters. Some Pix will be real nice Vic
How A bout Some Work
Vic
Autodidactic user
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
