Monkey Wrench
Spede's Avatar
Need high horsepower/torque 915 clutch recommendation
What's a good clutch to use with a 915 if I'm going to run 400-ish hp/torque?
Is there a cut off power level where I should consider switching up to a 930 tranny?
Thanks in advance!
Old 03-21-2006, 11:00 AM
What are you up to with that 75????
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 03-21-2006, 12:00 PM
Administrator
Jack Olsen's Avatar
If you're tracking the car, you've probably passed the point of needing the 930 box with that much torque.
Old 03-21-2006, 12:33 PM
rsa rsa is offline
rsa's Avatar
Kennedy Engineering 915HD plate 477 Ft/lbs
http://www.kennedyeng.com/porsc_pp.htm
Scott
77 911s
Old 03-21-2006, 12:36 PM
Crotchety Old Bastard
RarlyL8's Avatar
I use a Sachs Sport Clutch, engine output is about what you are listing. Works perfectly and is not too heavy.
I assume you're adding a turbo motor or a V8. Nothing else will get you that much torque.
Old 03-22-2006, 10:19 AM
Monkey Wrench
Spede's Avatar
Is that the same one as the Sachs Power Clutch as listed in the Pelican site?
Old 03-29-2006, 01:43 PM
RarlyL8's Avatar
They don't show a picture but the description and price are the same. So I'd say yes.
Old 03-29-2006, 07:18 PM
