Toothzilla's Avatar
Another shift coupler question
I can't get my porsche out of reverse, the first thing I was told to check was the shift coupler. Everything looked solid, but I removed it to check the bushings.
Seems like there's a lot of slop in the coupler. Is that how you know the bushings are bad?
TIA
chris
Chris
'02 996 TT
'84 Turbo Look
'72 911 Vintage Racer
06 Tacoma (Tow)
Old 04-02-2006, 08:25 PM
Slop in the coupler itself is ( unfortunately) normal...do a search where I mention this several times....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-03-2006, 05:16 AM
The aftermarket bushings I purchased from Pelican do not have the "factory" Porsche built in slop.
Old 04-03-2006, 05:22 AM
The original poster is advised to look at adjustment as well as the "other" area for bushing wear..like the ball/cup directly under the shift lever...
If everything worked before but you can't get it out of reverse...I'd suspect adjustment first....
- Wil
Wil Ferch
Old 04-03-2006, 06:20 AM
Toothzilla's Avatar
After taking the coupler out and putting it back in, it now shifts correctly.
What I was looking for was how do you "know" it's time to replace the bushings?
Chris
'02 996 TT
'84 Turbo Look
06 Tacoma (Tow)
Old 04-03-2006, 12:07 PM
