Mike the mechanic's Avatar
Anyone using Patrick's short G50 DME flywheel/clutch setup?
I am wondering if anyone else is using Patrick Motorsports' short G50 DME flywheel/clutch set-up. I am having trouble getting the rpm/reference sensors adjusted correctly. It seems as though they have to be adjusted indpendently of each other, which is impossible with the stock bracket. The car is exhibiting a crazy miss/hesitation at low rpm. Hoping maybe someone had a similar experience and can help out.
Thanks!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-21-2003, 06:14 PM
Anyone?
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-22-2003, 05:21 AM
Irrationally exuberant
ChrisBennet's Avatar
The stock 3.2 sensor bracket should hold both sensors in the correct location when the lower sensor is adjusted 0.8mm from the flywheel teeth. I don't know if that helps but I thought I mention it just in case...
Have you checked the sensor outputs with a 'scope?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 07-22-2003, 05:28 AM
Hi Chris, the Patrick Motorsports flywheel for shortened g50's is a little different than stock. It has the sensor ring very close to the engine case, and the actual reference sensor tdc pin is on the pressure plate. I was notified by Jim Patrick that I have to swap locations of the two sensors. Now, I have replaced both the rpm and reference sensors with new ones. (Are they both the same part number??) It seems that the reference pin is too far forward, and doesn't centre in the middle of the sensor when the rpm sensor is adjusted correctly. The only way i can make it run nicely is when the engine is running, I slide out he reference sensor. When it loses communication with the refernce pin, it seems to run better.
The funny thing is that before i got new sensors, the only way to make the car run well was to revert back to the original location of each sensor, meaning the rpm was on the reference pin and vice versa, but with that configuration, the car suffered the classic case of misadjusted rpm sensors. At anything over 3000rpm, the rpm guage started to move erratically and the engine missed.
I may have to remove the engine to compare the reference mark to the stock flywheel, but I want that to be my last resort!
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-22-2003, 05:58 AM
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-22-2003, 06:02 AM
Mike,
They are the same sensor/part #.
It doesn't seem likely, but I've heard that the reference sensor is only "used" during starting.
Maybe you can shim the sensor bracket so the reference sensor end is angled out i.e. closer to centered on the pin.
I wonder if the pin itself is at the proper height?
-Chris
Old 07-22-2003, 06:26 AM
Mike, Have you called Patrick yet? I know that would be painful but it might be helpful
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-22-2003, 09:30 AM
Dean, yes, I called Patrick, and he said that I should play with the angles, like Chris suggested. It's not working.
Chris, if you unplug the reference sensor while the car is running, the car continues to run fine, so it may be true about the reference sensor, BUT it wouldn't make sense in my case, where pulling out the sensor from it's holder makes the engine run better.
I will check the pin height as you suggested. If I knew how to attach an mpeg, I would post a small video clip of it running. Maybe that would help. I may be overlooking something stupid, which is usually the case, ie, overthinking.
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-22-2003, 05:39 PM
Tonight I tried unplugging the reference sensor on my running 3.2. It idles and responded normally when I blipped the throttle confirming what I'd been told.
I think you really need to borrow a scope to see what that signal looks like.
-Chris
Old 07-22-2003, 06:31 PM
I think you're right about getting a scope. The only thing is, I wouldn't know what to compare the signal to. By the way, I appreciate you taking the time to help.
Mike
03 996tt w/efr7163
89 Carerra 3.6
Old 07-22-2003, 08:39 PM
Mike,
I haven't done this myself, but the factory manual shows what the signal should look like. I think it is -0.5 to 0.5v. You could adjust your sensor position to get the best signal that way.
It does strike me as a bit odd (micky mouse?) that Patrick's solution isn't "bolt on". It's one thing to design and debug something yourself but when you pay someone for a product you shouldn't have to finish the R&D for them.
-Chris
Old 07-23-2003, 05:22 AM
1972_911T's Avatar
Did the issues with the patrickmotorsport short G50 flywheel/clutch kit for the 3.2 get sorted out? Im also looking at using a short G50 with my 3.2 conversion as an alternative to my mag 915. Has anyone actually got this conversion running satisfactory with the 3.2 DME?
Thanks Steve
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 04-06-2006, 02:57 AM
I don't think Patrick could solve the problem.
Give Dave at TRE a call. I think he has a solution.
Dean
Old 04-06-2006, 04:21 AM
