PeterTarga's Avatar
pop-off valve installation question
Hi,
I'm thinking to install the pop-off valve on mine 78SC but i see now that i have not enough place to drill the hole correctly (machine is to large), my question is now what should i do, buy me a right angle drill or a partial engine drop. I never did a partial engine drop, i saw it once in the workshop. What is the best solution, what is the risk of the partial engine drop, i think when i drop the engine 2" it should be enough.
Thanks,
Peter
Old 04-29-2006, 03:14 PM
Original Owner
tsuter's Avatar
Well if you don't have AC just remove the deck lid. Then you can drill straight down.
Else one of those bendable flex drill shafts will work as well for about $6.00
I'd remove the deck lid though even with AC....in fact I did....when I used to have a NA car and wanted a pop valve.
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 04-29-2006, 03:34 PM
PeterTarga's Avatar
Hi tsuter,
I don't have a AC, but also with the deck lid removed i can't reach the center point where i should drill.
Peter
Old 04-29-2006, 03:41 PM
Original Owner
tsuter's Avatar
I wouldn't think Euro is that much different. Its a straight shot down into the air box pop valve location with the lid off. Try getting the bendable/flex shaft extension for your drill. It will still be much easier with the deck lid off as the drill can be above the air box then.
tsuter
Thaaaats Right!!
Old 04-29-2006, 03:48 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I used a small right angle pneumatic die grinder with a hole saw. Plenty of room, no engine drop, with the decklid on. Cheap from Harbor Freight.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32046
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-29-2006, 04:32 PM
DavidI's Avatar
Peter, I used a right angle drill adapter that I bought from Harbor Freight for about $8.
It is a very easy job.
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 04-29-2006, 07:27 PM
craigster59's Avatar
Just do what I did. Convince the Wife that it's the perfect time to purchase that new tool you always wanted. It'll come in handy again sometime down the line.
Old 04-29-2006, 08:27 PM
PeterTarga's Avatar
Thanks, i gone buy me the right angle adapter.
Peter
Old 04-30-2006, 03:05 PM
