| Registered Join Date: Sep 2003 Location: Belgium
				pop-off valve installation question
			Hi, I'm thinking to install the pop-off valve on mine 78SC but i see now that i have not enough place to drill the hole correctly (machine is to large), my question is now what should i do, buy me a right angle drill or a partial engine drop. I never did a partial engine drop, i saw it once in the workshop. What is the best solution, what is the risk of the partial engine drop, i think when i drop the engine 2" it should be enough. Thanks, Peter | ||
|  04-29-2006, 02:14 PM |
| Original Owner Join Date: Dec 2002 Location: San Antonio, Texas
			Well if you don't have AC just remove the deck lid. Then you can drill straight down. Else one of those bendable flex drill shafts will work as well for about $6.00 I'd remove the deck lid though even with AC....in fact I did....when I used to have a NA car and wanted a pop valve.
				__________________ tsuter 78 911SC Turbo Targa Thaaaats Right!! | ||
|  04-29-2006, 02:34 PM |
			Hi tsuter, I don't have a AC, but also with the deck lid removed i can't reach the center point where i should drill. Peter | ||
|  04-29-2006, 02:41 PM |
			I wouldn't think Euro is that much different. Its a straight shot down into the air box pop valve location with the lid off. Try getting the bendable/flex shaft extension for your drill. It will still be much easier with the deck lid off as the drill can be above the air box then.
|  04-29-2006, 02:48 PM |
| Registered |
			I used a small right angle pneumatic die grinder with a hole saw. Plenty of room, no engine drop, with the decklid on. Cheap from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32046
				__________________ 1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater | ||
|  04-29-2006, 03:32 PM |
| Registered Join Date: Mar 2002 Location: Southern California
			Peter, I used a right angle drill adapter that I bought from Harbor Freight for about $8. It is a very easy job. David
				__________________ 99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) | ||
|  04-29-2006, 06:27 PM |
| Registered |
			Just do what I did. Convince the Wife that it's the perfect time to purchase that new tool you always wanted. It'll come in handy again sometime down the line.
				__________________ --------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain | ||
|  04-29-2006, 07:27 PM |
			Thanks, i gone buy me the right angle adapter. Peter | ||
|  04-30-2006, 02:05 PM |
