Clock Delete for Gauges +
I recently mounted a 2 1/16 VDO gauge (mine is boost) in the clock space using an adaptor cut from MDF and painted flat black. I'm also going to add a single LED voltage monitor :
http://www.signaldynamics.com/products/Modules/HUVM.asp to the plug. Given that it turns out that I have the hole saws to do this very easily, I'd be willing to make a small run of them for Pelicans. If there is enough interest, I could also do them for 2.5 in gauges as well. I'm thinking 15 bucks each. I can bring a few to Hershey if there is any interest. They do require a couple wraps of electrical tape around the invisible portion of the gasket for a secure fit, but you don't see it if done carefully and its very secure. I searched the online catalog here and didn't see anything, but if this conflicts with anything Pelican is doing, please delete.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Greg,
GREAT Idea! I like the voltage LED light. Doug
1971 RSR - interpretation |
