Crew Chief
Engine serial #
Can someone tell me what Engine this is :
The #'s on the block are : 901/06 9017 and 911940
Herbert B. GruppeB #093 Carolinas Region PCA Member National PCA Driving Instructor _______________ '71 911 RSR look '74 914 2.0 '76 911S Targa '83 930S Slantnose (13000 miles) '86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014 '86 951 '87 944 "Life is short , drive Fast" |
The Type 901/06 with that serial # was a late 1967 Normal 2-liter engine with 130 HP originally.
TT
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Crew Chief
What is it worth ( good running engine ) ?
Warren Hall Student
Since it's a 67' then the case should be aluminum so that's where the value of this motor lies. Not many people looking for 2L normal engines but that case is a good foundation for a small displacement race motor. I'd put value around $2000 to $2500.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Crew Chief
What was the difference between the L and the S engine ?
Warren Hall Student
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ Last edited by Bobboloo; 04-12-2006 at 01:25 PM.. |
Crew Chief
I thought the T had 110hp , the L 130hp and the S 160hp in '67.
Am i wrong ?
Warren Hall Student
Your probably right. I was going off of memory which doesn't always serve me.
TT
Carbon Emitter
Tom pretty much said it all, but to add to the confusion there was a 911L model for ROW too, replacing the "normal" 911 in the ROW market, and it did NOT come standard with 911S goodies. As far as I know there is no normal 911 in ROW for 1968.
So for USA: normal 911: 130HP smog motor 911L: 130hp smog motor with S trim. ROW: 911T: 110hp 911L: 130hp (no S goodies) 911S: 160hp Yep, 1968 was a wierd year.
