- Self Moderating -
Need advice on selecting torsion bar size...
Hi All,
A broken rear torsion bar has provided me the opportunity to go with something a little thicker. To my understanding my car has 19mm up front, and 24.1mm at the rear (85 carrera). At this point I will only be changing out the rears and was wondering what a good width might be, keeping in mind I will probably keep the fronts stock for a few years until more suspension work is required.
Would upgrading to 26mm at the rear for know be an ok setup with 19's at the front? This is for weekend driving and very little track time...
Any thoughts?
Tim
Present: 57 Intermeccanica Speedster Ivory on Brown
Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan
Old 04-22-2006, 10:09 AM
RonDent's Avatar
Jim, I changer mine over the winter. I run AX events with mine so I went with 21's up front and 29's in the rear. Pretty stiff for day to day but drives like hell. Maybe, 21's and 27's would be much better for street use with an improvement for track use.
Ron
'78 Targa Sold!
'84 Carrera Sold!
'01 996 Wrecked
Old 04-22-2006, 10:23 AM
- Self Moderating -
Thanks Ron. I bet she handles well!
Tim
Old 04-22-2006, 10:32 AM
ttweed's Avatar
Re: Need advice on selecting torsion bar size...
How much is "very little" track time? If you upgrade the rears and do nothing to the fronts, you're going to find the car oversteering more at the limit. If you never approach the limit, you will not notice this, but if you do track the car that way, it could be very loose. Disconnect your rear sway bar if you have one and run bigger tires in the rear if you can. Or just bite the bullet and do both front and rear now "while you're in there." You will need to have an alignment anyway, why do it twice?
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 04-22-2006, 02:14 PM
- Self Moderating -
Good advice Tom. Very little time is: I have never tracked or done a de and this is something I might do in the future. But not high on my priorities. Maybe I will do all while I am in there....
Tim
Old 04-22-2006, 04:25 PM
3.4 Bigger is better
88-diamondblue's Avatar
The 89 turbo ran 27 rears and 19 fronts prior to that the turbo's were 19 & 26. My 88 is 19 and 25 and will be upgraded to 21 & 28 next winter.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 04-22-2006, 06:24 PM
Cribbed this from my answer in another post...
- Wil
Here's a breakdown of front and rear TB sizes and their spring rates ( EDIT..effective wheel rates), after my exhaustive investigation on sizes, bar lengths, pivot arm lengths, etc:
Front:
18.8= 110 lb/in
21= 173
22=210
23=250
Rear:
24=120 lb/in
25=140
26=165
27=191
28=221
29=254
30=294
31=332
33=427
Notice some interesting trends.... many people say to upgrade to 21/27...or 22/28. The 21/27 combo equates to 173/191...and the 22/28 combo equates to 210/221. In both cases...fairly equal. This maintains the front/rear balance Porsche designed into these cars, but some say (me included) that we can go proportionately stiffer in the rear to dial-out some unwanted low speed understeer. So...maybe 21/28 ( 173/221)....or 22/29 ( 210/254).
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-23-2006, 02:36 PM
Warren Hall Student
Bobboloo's Avatar
Absolutely, Good choice for a street car.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-23-2006, 02:50 PM
Platinum Member
dad911's Avatar
Turbo engines are heavier, I don't think you would want the same torsions in a NA car????
Speedracer - the fronts are simple to change compared to the rears. So if you try a bigger bar, the fronts can be changed to balance the car if necessary.
Have you done any other suspension work? Are the struts, bushings, sways original?
Even though Turbo's might be heavier...their "stock" set up can be readily used as a mild street upgrade for a NA car....19 fr / 26 rear is not a bad thing..
Wil
Wil Ferch
Old 04-23-2006, 03:31 PM
- Self Moderating -
Thanks for all the input guys. I am not sure if the rest of the suspension is original I am going to take a closer look at it. Thanks again.
Tim
Old 04-23-2006, 06:03 PM
nostatic's Avatar
I would say do both and all associated bushings. Odds are they are very tired...
I went 23/31, but that's for a primarily track (though still street legal and regularly driven) car. The change in handling was significant on the street, and downright terrifying at the track. Took the the whole weekend just to get back to having a handle on what the car could/would do...
I have to wonder how much of this was due to the worn/sloppy bushings and other bits on the old setup...
Old 04-23-2006, 06:11 PM
