What does the a/c compressor clutch do?
I was replacing my engine mounts today and I had to move my a/c compressor to get at the mount on the right side. When I did, I found that the single wire coming out of the compressor clutch is disconnected. I bought the car over the winter so I haven't tried to use the a/c yet. What does this wire do? Should I just plug it back in? Is there a reason for it to have been disconnected?
Thanks for the help,
Sean
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 04-22-2006, 03:35 PM
Zombie
it acts as a magnetic couple to your ac compressor when its switch on it engages your pump
Old 04-22-2006, 03:41 PM
Immature Member
dentist90's Avatar
Sean,
It may have been disconnected to make sure that the compressor wasn't accidentally activated by the AC switch inside as your system may not be charged or in good working order. Of course, removing the V-belt would also guarantee the AC didn't turn on. If you have any doubt it would be a good idea to take it to a garage to see if the system holds a charge (ie doesn't leak) before you allow the compressor to turn.
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 04-22-2006, 06:59 PM
Retired Member
Brian 162's Avatar
Could be the system is flat or the relay could be sticking allowing constant power to the compressor.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 04-22-2006, 07:20 PM
Immature Member
dentist90's Avatar
You can perform a quick check to see if the magnetic clutch is working. Just remove the V-belt (if its installed) and spin the AC pulley. It should be free wheeling. Then go into the car and turn the AC fan knob to any position above "0". You should hear the blower come on (with the igntion on). Go back to the AC compressor and now the pulley should be "locked" and turn the compressor. You don't have to actually start the car to do this. If all checks out OK just get the system inspected and recharged.
Old 04-22-2006, 09:33 PM
Send a message via AIM to fintstone
To make it simple, the compressor pulley normally spins freely. When the clutch is engaged, the pulley locks to the shaft and actually turns/runs the compressor.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-05-2010, 09:24 PM
If it's an original York compressor ('71 or '82), hook up the wire and see if the compressor works.
They didn't have a high/low pressure switch and will run even without freon. Won't hurt it for just a minute or so.
Old 05-05-2010, 09:58 PM
