Immature Member
dentist90's Avatar
Question Normal Residue on AC Compressor?
Have a look at these photos... is this black, oily dust normal for the AC compressor. I suspect it's just like brake dust, but from the magnetic clutch. Everything seems to work fine and the compressor doesn't make any noise.
It doesn't necessarily indicate a problem with a shaft seal or anything like that ? (he asked optimistically).
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 04-23-2006, 12:16 PM
Jastx's Avatar
After the A/C is charged, as the hose is removed from the high-pressure line on that side, a discharge of the refrigerant under pressure happens. It deposits a light coating of oil on everything in the area that dust sticks to. That's probably all it is.
John
2005 997 Carrera S -- Artic Silver/Sea Blue
Former friends: 1989 930 factory Slantnose /
1998 C4S Coupe / 1973.5 911T / 1976 914 2.0
Old 04-23-2006, 01:12 PM
Immature Member
dentist90's Avatar
Oooh, Good answer! I like it. I'll just clean it up and hope it doesn't come back then.
Derek
Old 04-23-2006, 01:20 PM
It could also be particles from your belt.
Tony G
2000 Boxster S
Old 04-23-2006, 01:23 PM
Look for dirt stripe on the underside of the engine decklid in line with the compressor pulley; if you see one you may have a compressor shaft seal leak.
Old 04-23-2006, 05:05 PM
