cantdrv55's Avatar
SOS - did I install the pilot bearing the wrong way?
I have an early SC motor (78 - 79) so the pilot bearing doesn't have the three bolts that connect it onto the flywheel. Instead, mine has to be pressed in. I can't seem to find a good pic of this so I had it pressed in the way I thought it should go, but now it looks wrong to me. If you know for sure, could you chime in? Below are pics of what a machine shop didfor me. Is the pilot bearing pressed in the wrong way around?
Old 04-22-2006, 07:17 PM
that's correct.
206 637 4071
Old 04-22-2006, 09:52 PM
cantdrv55's Avatar
Sorry John. Did you mean that it is installed correctly as it is or that I installed it the wrong way? Thanks in advance.
Old 04-22-2006, 09:55 PM
It is installed correctly. It has to be pressed in from the side that faces the crankshaft. You can see the collar on it that goes into a recess on the side that faces the crankshaft. Don't forget to grease it.
-Andy
Old 04-22-2006, 10:08 PM
cantdrv55's Avatar
Thanks guys!
Old 04-22-2006, 10:15 PM
vash's Avatar
sweet! see you in the AM. get tylenol ready...
poof! gone
Old 04-23-2006, 12:22 AM
