data logger - RPM signal?
I just bought a G2X data logger. I haven’t received it yet, but I am already researching on installation and set up. ..I am very anxious!!!
The manual says that “the tachometer input requires 5-18 Volt, 50% duty cycle, square wave output signal"
Anyone knows if this is compatible with what the ECU of a '97 993 Vario engine will generate?
Also, on the setup process the user has to specify the number of pulses from the tachometer signal for two revolutions of the engine. What would be that magic number???
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 04-27-2006, 12:26 PM
The Racepak software will have everything you need to set the pulses properly. I am using this system on a test car now and can help you get things set up correctly. The manual they have included with the logger is very good as well.
Good luck and feel free to contact me if you need any help.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 04-27-2006, 01:06 PM
Thanks James. i will probably bother you in a short while.
Are you using the RPM signal input, or are you taking it directly from the cigarette lighter power connection?
Mario
'15 GT3
Old 04-27-2006, 02:23 PM
On the car I have it on I tie in to the tach signal.
James
Ayrton Senna
1993 964 RS
Old 04-27-2006, 02:50 PM
