location request for badges
I'm adding an early aluminum (pre 74) grill to my tailess decklid along with a custom "3.4" badge from Pelican. The grill does not have the indent for the "2.7" or similar early engine badge. Can someone post a pictue of where this goes, or better some quick measurements from the edges to the center. Also, where specifically does the "Carrera" side script go? I would imagine the word carrera is centered between the wheel wells. I was told the script should be 2" from the bottom edge of the door. Sound right? Thanks.
The Carrera decals are placed 50mm up from the bottom edge of the doors. The "C" on the left one starts 10mm aft of the door edge and the right one has the end of the "a" just touching the rear edge of the door.
The badge ought to be between the 7th and 8th grille bars, from the top. The right edge should be around 1 1/3 badge-widths to the left of the right edge of the grille. I hope the last bit makes sense. JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
Makes perfect sense, thanks.
Anyone have any pictures with these in place? Thanks.
