Retired Member
Charlie V's Avatar
Wiper Wiring Question - HELP
I'm putting the wiper motor back after painting the car. Need help in getting the wiring to the correct connection.
The back of the wiring connection on the wiper motor is labelled as.....
As you can see it is not clear as to what pin is what number. I have tried every combination I can think of and blow a fuse each time. Must have gone through 7 fuses so far.
I can get the wipers to run, but not stop. Or run and blow a fuse on high. Or just blow a fuse.
Wiring diagram in Bentley has:
53E blu/wht
53A red & red/wht
53 blk/vio
53B blk/yel
53I grn
31 brn - this one has a ground connector on the motor away from the connector.
This corresponds to the wiring I have.
Can anyone assist in identifying the correct connector numbers??
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 05-31-2008, 06:23 PM
Sports Purpose 911 Driver
mjshira's Avatar
did you search a few times? I recall that this wiring has been posted before. also I think the diags are hosted by Wayne also here. if you can't find either let me know tomorrow and I can check my stash of old threads.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 05-31-2008, 07:23 PM
Retired Member
Charlie V's Avatar
I tried searching a couple of days back. Found nothing specific. Tired more searching just now and found this....
Wiper Motor Wiring
Exactly what I need.
Thanks.
Old 05-31-2008, 08:31 PM
