Where to mount crankfire coilpack on CIS engine?
Usually, I see the coil packs on a shelf off of the rear suspension crossmember.
But on my car, all that CIS stuff is in the way. I don't want to put it under the oil filter... Anyone have a tidy installation idea? TIA
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I did this...
http://members.rennlist.org/dougcl/911S010.jpg not sure if I would call it tidy, but perhaps this will get the thread rolling. I made my own panel. I would rather fit them in there with the stock panel in place. Doug |
Saw a picture of one coil pack that was mounted where the distributor came out. A little metal work to bend up and mount a shelf, and it appeared to fit nicely. Raise it up just high enough to clear the sensor that you will probably mount to the old distributor clamping stud.
If I can remember where I saw that pix, I'll post it back to you. PS: on second thought, the coil pack was a Ford EDIS pack. Last edited by Brian K. Haggard; 04-28-2006 at 07:47 AM.. |
Me like track days
Personally I think this location is the best:
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Craig, I like that location, but the crankfire system has tuning settings and also contains the coils, so I'd be running the sparkplug wires through the firewall, which bothers me, for some reason.
Me like track days
You'd be running plenty of other wiring; I'd just do the small hole w/ a grommet and have the engine compartment nice & uncrowded.
Other people really like the 'wow, look at all my trick stuff' look when they open up the engine lid, so I suppose it's also a matter of subjective preference.
Neil Peart Fan
Deleted heater blower and bolted mine to rear of engine bay.
Wer bremst verliert
Does anyone run their 6-plug coils inside the car? My engine compartment is rapidly becoming crowded with Intercooler, supercharger, etc. I'm considering building up a mounting panel to quick-release (butterfly dzus-style) to the firewall and then mount my ignitors, ECU, MAP sensor and relay panel to that. I'm also considering putting the twin EDIS 6-post coils on that or another panel inside the passenger compartment.
Advantages...1. accessibility (engine bay very crowded) 2. Weight is farther forward and lower 3. would look pretty cool Disadvantages...1.would require running the wires through the firewall (pic below of a potential solution 2. increased electrical field interference? that would be 12 high-tension wires in close proximity to the ECU (which uses a bluetooth transmitter/receiver to connect to my laptop during tuning and logging) 3. twice as many connections to come loose. Here's a solution Summit sells, interested in comments... ![]()
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
I run a 6 of my dual plug coils on the engine side of the fire wall. I have my ecu and ignition driver box on the inside of the firewall like it craigs pic.
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
![]() ![]() With our CIS to EFI conversion, we mount the EDIS coil pack here..... ![]() Dont know if theres enough room w the crank fire, but it may be worth a look. Len@autosportengineering.com ![]() |
