GotaT's Avatar
Send a message via AIM to GotaT Send a message via Yahoo to GotaT
SANDEN 507 AC Comp
I am trying to get more info on a Sanden 507 AC compressor. If one of you have one could you look at it and look for any labels or #'s that are on it to determine which one it is. I found this one and think this might be it.. Can anyone make a determination or give info off of theirs?
https://www.acparts.com/product.php?productid=278371&cat=0&page=1&featured
Old 05-27-2008, 01:20 PM
Wildman Emeritus
It does not look like the 507 sitting in my garage awaiting installation. The back is vastly different.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-28-2008, 09:17 AM
GotaT's Avatar
Thanks,.. Any #'s on yours to depict it?>
Old 05-28-2008, 09:42 AM
Wildman Emeritus
Let me get a look at it tonight and maybe a photo.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-28-2008, 10:44 AM
Wildman Emeritus
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Barrpete's Avatar
Don't have numbers but that looks waaaaay different than mine. Here's pic
1986 Carrera Coupe
1999 Chevy Tahoe
1987 Chevy Blazer
1955 Chevy Apache 3100 Pickup
"A little knowledge is a dangerous thing"
Old 05-28-2008, 01:04 PM
doesnt look like my sanden 508 either.
Old 05-28-2008, 01:12 PM
Wildman Emeritus
That's mine also.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 05-28-2008, 01:19 PM
Make Bruins Great Again
Por_sha911's Avatar
Sanden in my `87
Joe
Old 05-28-2008, 03:44 PM
The Sanden SD507 doesn't appear to be on that website. Why not call or email them, their prices look pretty good.
Old 05-28-2008, 03:59 PM
Nitrometano's Avatar
The sanden 507 came with the o-ring type fittings or with the flare type fittings. Also the pulley is for the single or dual belt or with the serpentine belt. Mine is like the one that appears on the photo that Joe taked.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 05-28-2008, 06:25 PM
and the back cover plate can be changed for one with either flare or o-ring fittings.
it uses a rolled edge metal gasket.
Old 05-28-2008, 06:30 PM
GotaT's Avatar
Dont the early cars require the 508? Can they be fitted with Either the Flange or O ring fitting.. which is preferred?
Old 05-29-2008, 06:03 AM
In my case that I have Webers on my 72 911, the 508 is longer than the 507 for about 1/2" and the compressor would not fit. My brother have in his 77 911 that have CIS a 508 and fits with out any problem. The flare or o-ring type fittings is not a problem. When I installed my 507 I used flare fittings on the hoses, thats why my 507 have flare fittings. I think that the o-ring fittings seals better than the flare ones, the reason is that with the time and with the vibration of the engine, the fittings tends to get loosed a bit. In the o-ring ones, the o-ring is the part that makes the seals job, so the fitting nut just hold the o-ring in place. I notice that when my 507 broken on december last year, was more dificult to find it than the 507 o-ring type one. But note aside, my 507 worked prefecty for about 9 years and daily use. I think they are very reliable compressors and the best of all, they cheaper than the original ones and works great.
1972 911T
Old 05-29-2008, 05:56 PM
GotaT's Avatar
Sounds like the 507 is the one for me.. 2.4 w/ WEbers and short stacks K/N's .. Nitro, you have a pic of your setup?
Old 05-30-2008, 06:55 AM
Throw it on the ground!
Not totally sure but Sanden 507 may = SD5H14
Check out post #18 on this thread:
Let the AC fun begin....oh to blow 45!!!
Sanden 508
http://www.rjays.com/Air-Cond/hra-compressors-01.htm
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 05-30-2008, 08:16 AM
In this picture the car have the old 507. I replaced for a new identical one on december 2007. But they are the same:
1972 911T
Old 05-30-2008, 06:20 PM
Have a 508 on my SC.
Old 05-30-2008, 06:54 PM
kuehl's Avatar
What you are looking at in the URL below is a "SD7H15", not the compressor you want for your set up. The unit shown there has "pad" port mounts which are not common hose fittings.
On my 73t we used our 507, no clearance issues with our Webbers (short stacks and low rider filters: PMO can help you out on that end). Most 507's have a two groove pulley (a "2A") and we simply cut off the outer groove so it does not touch the deck lid.
Old 05-31-2008, 06:46 PM
