HFR_Racer's Avatar
Unhappy Wipers work but washer doesn't...
Is the windshield washer switch a common point of failure on an 86 model?
My washer pump motor checks out ok but the switch on the column won't turn it on. Can the switch be checked or changed out without pulling the steering column? If so, how do I remove the plastic steering column cover over this switch?
Thanks in advance..
Thank you,
HFR_Racer
'87 930, 3.3 liter, K27 hybrid, Kokeln IC, Andial, B&B, Borla, 17" Supercups.
Old 10-13-2005, 08:18 PM
Will program for food
ghnat's Avatar
Get 101 projects from our host - good info, and Bently manual.
You will need to remove the steering wheel to gain access to the switches. With about 6 small bolts/screws to remove.
I am not sure if the washer switch is a common one to fail, but after 20 years - well I guess some will. Seams early with only 56k on your odometer. Maybe the PO used the washer more than average
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 10-13-2005, 09:05 PM
What may have happened is the mechanism in the pump jammed from disuse. It happened to me, I gave the thing a whack, and it works again. I just try to remember to use it more frequently now.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 10-13-2005, 09:35 PM
HFR_Racer's Avatar
Pump works fine and I have the 101 projects book.
Thank you for your input.
Thank you,
HFR_Racer
Old 10-14-2005, 02:35 PM
What was the problem ??
I'm in the middle of something very similar...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-29-2006, 11:05 AM
See my post on this topic here.
Brian
Old 04-29-2006, 01:33 PM
