HELP! 87 3.2 Motor doesn't start after hot, but when cool NO Problem???
Need Advice,
My motor which is stock, doesn't kick over at all when hot and shut off,
but when cold, engine starts fine??????
I went to Coachella this weekend, and when the motor was warm with normal oil temps etc. and I try to start the warm motor, it doesn't even kick over--
I left the car for several hours, and returned in the cool nite, and it started up immediately!
Is this a starter issue or selinoid that heats up and won't start, or the ignition switch, or vapor lock fromaccumilator?????
I tried the lights thinking maybe the battery was at fault, but lights are ok, and last nite when it happened the 2nd time, I had AAA jump it and it wouldn't even try to start--- all I hear is the fuel pump? noise and nothing after that....
Thanks in Advance!
Going to try the "hit the starter with a hammer" theory and jump start it to drive it to the shop for repairs..
Patrick
1987 Targa Carrera
Granite Green Metallic
Daily Driver
Pulls in 5th gear-Amazing!
http://www.pelicanparts.com/gallery/speccarrera
Old 04-30-2006, 05:01 PM
vinny c's Avatar
Sounds like the solenoid. Same thing happened to me. I replaced it with a lt. wt. starter and haven't had any problems since. Takes about an hour to change out but greasy. Try this linkhttp://cgi.ebay.com/ebaymotors/PORSCHE-911-MINI-STARTER-ALSO-PORSCHE-9Vince
Old 04-30-2006, 05:14 PM
Send a message via ICQ to fly944
Also check your grounds.
Old 04-30-2006, 05:25 PM
Thanks for responses--- found same problem listed on forum...waiting for light weight starter off ebay-- spoke to Otto and will take it to his shop for install-- with the G50 trans, worried about going over the 2" tolerance for engine removal and creating more expense...
1987 Targa Carrera
Daily Driver
Old 05-02-2006, 04:32 PM
drag racing the short bus
dd74's Avatar
I had the same problem as you; the car wouldn't start after getting warm to hot. In my case, it was the starter motor, but I also had the ground strap replaced only because it aids with the current flow as well as after over twenty years, the straps become somewhat frayed.
The Terror of Tiny Town
Old 05-02-2006, 04:46 PM
good idea... will order a ground strap from Pelican and do both upgrades... going through the starter troubleshooting tech article and will test the grounding before/after with voltmeter...
1987 Targa Carrera
Daily Driver
Old 05-02-2006, 04:52 PM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
Check the DME relay under the driver's seat.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 05-02-2006, 04:58 PM
Will do.. thanks Zoanas!
How do you like the Hella's over the stock fogs?
I might do that upgrade instead of driving lights for better canyon illumination...
1987 Targa Carrera
Daily Driver
Old 05-02-2006, 05:06 PM
UFLYICU
ZOA NOM's Avatar
They are absolutely DEADLY at night! High speed night driving is worry-free. They throw major light a full mile down the road.
prc-racing.com
Old 05-02-2006, 05:10 PM
Nice! Will see the deer freezing in their tracks way down the road!!!! hahhahaa
1987 Targa Carrera
Daily Driver
Old 05-02-2006, 05:22 PM
