Brando
quattrorunner's Avatar
oil temp issue solved?
I have had a problem with my oil temp since getting it put back on the road after being stolen. I just couldn't figure why my temps are so damn hot(9:00 to 9:30 posistion on the gauge) I have a 79sc and never had any problems before, but then it was stolen and made to be ghetto fabulous. In the "conversion" I guess they maynot have had the correct jacking methods at their disposal and I have some bug dents around the jack plate receptable. I also have a big dent where the line goes up into the front fender. My guess is that the oil isn't moving fast enough to do much good in the trombone? I found this checking for fitment of a new mocal cooler I got. The tire was out of the way and this is the best oppertunity to check things out since the issue was noticed. Am I at the end of my quest for the issue? I feel this is got to be the (expensive) reason. Any thoughts?
Turbo powa!
1977 911s. it's cool
Old 06-28-2006, 11:34 AM
Brando
Has anyone repaired these lines? I assume you can sweat brass and copper with brass rods? Looks easy I guess after removing and cleaning.
Turbo powa!
Old 06-28-2006, 12:33 PM
bigchillcar's Avatar
same thing i was thinking. i don't know for sure, but i'm sure someone like chuck moreland of elephant racing who sells lines, coolers, etc. could answer your question..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-28-2006, 02:12 PM
Brando
Thanks chill,
I tested a couple copper pipes with brass rod and it stands up to the added heat. I'll be doing a repair in the next couple days. I'll keep posted.
Turbo powa!
Old 06-28-2006, 02:26 PM
Brando
pics
Here are some shots of the lines that are damaged. What do you think?
Turbo powa!
Old 06-29-2006, 11:47 PM
Send a message via AIM to fintstone
Your insurance should replace those lines (after theft damage). They are terrible. No wonder you are hot.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 06-30-2006, 12:32 AM
Brando
I didn't claim anything so it doesn't have a bad title. The car is great other than this, infact this is the only damage I have, other than the fact he painted everything incl;uding rubber and the roll bar Plus, he took my fuchs
I fixed everything back to rightious.
Turbo powa!
Old 06-30-2006, 08:15 AM
