goldgunner's Avatar
Rear Window - Seal
I'm finally close to installing the rear window - after much struggling...
My question is this:
The top of the window / top of the window seal - obviously fits inside of the rear window recess.
Does the bottom of the window seal also fit entirely inside the recess? That is, does the outside flange of the window seal ('outside' of the seal aluminum molding) at the bottom and for that matter the bottom half - sit entirely inside the rear window recess?
Or does the rear window seal outside flange transition from the inside of the recess at the top to 'on top' of the recess at the bottom?
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 05-04-2006, 06:24 AM
goldgunner's Avatar
Help - I'm in the middle of this install~!
Just a quick look at your rear window is all that it would take to answer my situation - puleese?~!
Old 05-04-2006, 08:42 AM
Yellowbird RS's Avatar
the top of the window seal fits inside of the rear window recess and the half of the bottom window seal fit inside the recess the other half recess in the window frame
Make sure that you place the glass into the car with the top lip first and the the bottom lip should place in the right position
X/A
Old 05-04-2006, 08:57 AM
goldgunner's Avatar
thanks - let's make sure I've got it:
Top of window seal fits inside of the rear window recess - yup
Bottom of window seal fits outside of the rear window recess - on the car body / recess 'surround' ?
The sides of the window seal transition from inside the recess (top) to outside/on top of the recess (bottom)?
Correct or nay?
Old 05-04-2006, 09:17 AM
MAGA
Tim Hancock's Avatar
On my SC, it is how you describe.... The upper portion is seated down inside and the bottom outer lower seal lip just rests on top of the body.
That said, I installed it myself and at the Hershey swamped swap meet last month, after sitting out at the motel overnight during a 1"+ rain, I had leakage somewhere from this seal. (I have not had time to re-examine where or why it leaked)
The previous seal in the car was oriented the same (I can't guarantee it was the original though).
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 05-04-2006, 09:34 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-04-2006, 12:35 PM
