Some times my car won’t start.
If I rotate the idle screw on the intake almost all the way to the left and try it……..
it starts
Then I have to bring the idle back down.
It does this about every 2 days.
Any ideas?
Old 05-04-2006, 02:10 PM
Designer King
Paulporsche's Avatar
Is this a CIS car?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-04-2006, 02:15 PM
Thrasher's Avatar
Would you walk into the hospital and say "Hey Doc, I don't feel good - what's wrong with me?"
You're going to need to give us a bit more data (like what year your 911 is - could be carbureted/fuel injected; could be computer-based (>=1984), etc.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 05-04-2006, 02:17 PM
cis car no computer
Old 05-04-2006, 02:19 PM
Thrasher's Avatar
Ok, well there you have it.
Remove 3.0 and install 3.2 w/DME
Hey, it's a free bump!
Old 05-04-2006, 02:37 PM
sure go 50/50 with me since its your advice there are 2 for sale on ebay right now
Old 05-04-2006, 02:40 PM
Scott R's Avatar
All the way "left" if I am interpreting this correctly would be opening the bypass and letting more air through. Questions:
1. Do you have to do this only when the car is cold?
2. Have you changed anything recently? e.g. sensor plate height, basic mixture seeting?
Again, another request for the exact year if you can post it.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-04-2006, 02:41 PM
year 78/79
i only have to do this if i have "driven " the car and shut it off then need to turn it on within 10 min.
If it sits more than 20 there isnt a problem.
i havnt changed anything it has always been like this since i got it back in the car
Old 05-04-2006, 02:56 PM
Scott R's Avatar
Sounds like a basic mixture setting issue, or a leaky injector or some such.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-04-2006, 03:19 PM
Designer King
Check your fuel pump check valve and fuel accumulator. Also your control pressures.
Paul
Old 05-04-2006, 03:26 PM
all new
wait where is the check valve and what does it do?
Old 05-04-2006, 03:27 PM
Scott R's Avatar
Originally posted by favrok01
all new
These are all items that you will need a CIS pressure tester kit for. It's a good investment, you can get them from JC Whitney, Harbor Freight and other sources.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-04-2006, 03:33 PM
was that a answer?
Old 05-04-2006, 03:35 PM
Rodney Nelson's Avatar
That sounds totally like the fuel valve to me located right on the fuel pump it self.
The symptoms I had with my SC are as follows:
Car starts perfect when it is cold no issues
Car starts perfect if sits for a while after running it
Car does not start after running it, like stopping at the quickie mart.
My answer was simple, the valve located on the fuel pump. Just go ahead and change, a pretty simple job, and cheap too. And if it hasn't been done it will need to be in the future.
Good luck,
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold
Old 05-04-2006, 03:43 PM
picture?
price?
part number?
link ?
Old 05-04-2006, 03:45 PM
Okay,
Here is a picture of it...............
Do searches and see if you can find a part number. I did see that it costs about $17. Every new pump comes with one on it. I tried to see if pelican carrys it but I did not see it online. But, you know what Wayne says, "Just Call" so I bet they can get if for you.
Good luck.
Old 05-04-2006, 04:22 PM
well i tell you its so damn inexpensive it wont hurt to try thats for sure
Old 05-05-2006, 05:12 AM
