Southern Class & Sass
WTF: Caliper piston orientation
I rebuilt my caliper about a year ago. I made sure I aligned the pistons *perfectly*. Today I removed the caliper to install new rotors, and what do I find? Two things. First, the pistons have rotated to all sorts of positions. Second, the dust seals are fried.
Dixie Bradenton, FL 2013 Camaro ZL1 |
I believe the orientation is to prevent the leading edge applying more pressure than the rest, to reduce squeeling; but it is my opinion and worth about .02.
Donnie Currently Porsche-less.....
Re: WTF: Caliper piston orientation
Assuming that you have stock Carrera calipers, piston orientation is not critical like it is on 930 calipers,.... ![]() AFAIK, there is only the OEM seals for these calipers; if you are frying them, you have a severe temperature problem that will likely call for a caliper/rotor upgrade of some kind. Brake cooling kits do help in situations like these, but they simply are no substitute for a big brake upgrade.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
