Question 1985 911 Motronic Tach Signal
I have installed a PLX Devices wideband O2 sensor in my 1985 911 track car. I need to tap the tach signal wire (vilet/black I think) and enter into the PLX device two data signal points. For example, 20Hz at 1000RPM and 150Hz at 5000RPM.
Questions: 1) Can anyone confirm the wire I should tap and 2) Does anyone have the tach signal frequency output for my Motronic box?
Thanks. Craig
3.5L NA - 300HP
Old 06-25-2006, 02:52 PM
Irrationally exuberant
ChrisBennet's Avatar
I posted what you're looking for in this thread: Tachometer pulses per Rev??
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-25-2006, 02:58 PM
Thank you Chris. This is exactly what I need.
Craig
Old 06-25-2006, 03:01 PM
