Tachometer pulses per Rev??
Anybody know how many "pulses per revolution" an 87 Porsche Tachometer is expecting?
David |
Irrationally exuberant
I don't know if this will apply to a 930. This is from a Carrera ('88?) measured at the back of the tach:
100 Hz at 2000 RPM 200 Hz at 4000 RPM My cat is better at math than I am (despite doing lots of 'nip when she was younger) so I asked her. She gave me that "Are you an idiot?" look and then told me: "100Hz equals 6000 pulses per minute at 2000 RPM or 3 pulses per revolution." Hey, I could have figured that out... Hope that helps, Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Tim
1986 911 Cab 2008 Audi A6 |
So my cat was right? Good kitty! My circumstances are a bit difficult but I'm irrationally exuberant (as usual). Did my first motor drop of the year yesterday. Maybe I can beat my record this year (8 in one year)? -Chris
Thanks Chris this was very helpful. On my latest software upgrade for my DTA EFI system the "tach pulse per revolution" has been added as a user input from 1-6.
David |
Tim
Chris,
I am curious about the images you posted; are they from a regular computer...? if so which software, etc. David
David |
-Chris
/ J edit: oops, chris beat me to it. I should have refreshed the thread before replying.
'86 coupe |
Chain fence eating turbo
So the tach receives the signal on Carreras from the speed sensor, not the reference sensor?
no the tach signal comes from the Motronic DME unit
the DME receives a reference signal from the flywheel sensor, the Motronic brain then calculates when to fire the ignition based on that signal and a couple of other inputs.
Just figured out from an older post by Lorenfb.
The reference sensor is only for startup, the speed is for the DME which then translates firing impulses which ultimately feeds the tach. |
