Window switch hookups/wiring on driver door - help.
Help - hastily pulled my drivers door panel to do some work in the door and did not mark the wires when unplugged from the window swtiches. Yes, i should know better...
anyone have a wiring diagram they can share? everything worked fine but need to know where the red/blue/brown wires, etc go on the back of the driver and pass. window switches. Trial and error just blows the fuse.... thanks in advance. |
looking at the back of the driver side switch...
top left: red w/blue stripe top right: brown middle left: blue w/black stripe middle right: blue bottom: double red w/blue stripe Good luck. Bill
Bill M 88 Carrera 86 944 SP1 06 Cayman SPC |
Should've mentioned this is from my '87.
Bill
The easiest way to remember this is that the brown wire and the red wire with the short jumper go on top, the other end of the jumper on the bottom, the other two in the middle.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
thanks a million - i think this may save me...
wife surely didnt appreciate the hour ride home sunday with windows halfway up. |
which leads me to ask
is there an easy trick to get wires from the body into the door?
the openings in the door seem to be in an impossible place to acess. |
above wiring instructions worked - thanks!!!!
