schoward's Avatar
Window switch hookups/wiring on driver door - help.
Help - hastily pulled my drivers door panel to do some work in the door and did not mark the wires when unplugged from the window swtiches. Yes, i should know better...
anyone have a wiring diagram they can share? everything worked fine but need to know where the red/blue/brown wires, etc go on the back of the driver and pass. window switches. Trial and error just blows the fuse....
thanks in advance.
Old 05-14-2006, 06:35 PM
looking at the back of the driver side switch...
top left: red w/blue stripe
top right: brown
middle left: blue w/black stripe
middle right: blue
bottom: double red w/blue stripe
Good luck. Bill
Bill M
88 Carrera
86 944 SP1
06 Cayman SPC
Old 05-14-2006, 07:02 PM
Should've mentioned this is from my '87.
Bill
Bill M
88 Carrera
86 944 SP1
06 Cayman SPC
Old 05-14-2006, 07:04 PM
greglepore's Avatar
The easiest way to remember this is that the brown wire and the red wire with the short jumper go on top, the other end of the jumper on the bottom, the other two in the middle.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-15-2006, 04:17 AM
schoward's Avatar
thanks a million - i think this may save me...
wife surely didnt appreciate the hour ride home sunday with windows halfway up.
Old 05-15-2006, 05:32 AM
saintz's Avatar
which leads me to ask
is there an easy trick to get wires from the body into the door?
the openings in the door seem to be in an impossible place to acess.
Old 05-15-2006, 05:53 AM
schoward's Avatar
above wiring instructions worked - thanks!!!!
Old 05-27-2006, 02:13 PM
