-   -   3.2 Lowered Before and After...is it Too Low? (http://forums.pelicanparts.com/porsche-911-technical-forum/282163-3-2-lowered-before-after-too-low.html)
Rad Hatter 05-11-2006 07:15 PM
Re: Just right
Originally posted by turbo3six
Lowered and corner balanced since 1989, Love it!
Wow that looks familiar - about the same height as mine- original shocks?
http://forums.pelicanparts.com/uploa...1147398726.jpg http://forums.pelicanparts.com/uploa...1147398767.jpg[img]
Wow that looks familiar - about the same height as mine- original shocks? superb thanks for sharing
;) Rich
Elombard 05-11-2006 07:16 PM
I cannot believe that doesnt Rub - amazing.
turbo3six 05-11-2006 07:17 PM
Yes, original shocks and still good!
Rad Hatter 05-11-2006 07:29 PM
same height
Virtually identical height http://forums.pelicanparts.com/uploa...1147400936.jpg http://forums.pelicanparts.com/uploa...1147400978.jpg
turbo3six 05-11-2006 07:30 PM
Different suspension but LOW
H&R sport springs OEM shocks, corner balanced
http://forums.pelicanparts.com/uploa...1147400936.jpg http://forums.pelicanparts.com/uploa...1147400973.jpg http://forums.pelicanparts.com/uploa...1147400997.jpg
Rad Hatter 05-12-2006 12:58 AM
Now that looks terrific !
What are your measurements?
Cheers
lateapex911 05-12-2006 03:33 AM
Originally posted by Elombard
I wonder if the susp. is too low and the geometries are screwy? ......., maybe the tuner shops have found this faster at the track? DWSD's car comes to mind. I am assuming they re-aligned after they lowered?
(Sorry if any of this sounds harsh....)
Thats the crux of it.....
What do the geometries do at those ride heights? Is the front end in a good part of the bump steer curve? Are the control arms at a high angle?
What about front roll centers in relation to rear roll centers?
What about suspension travel? Is there sufficient travel before the car hits the bump stops??
What about the springs and shocks? You say it's soft. Well, lowering a Porsche won't affect the "feel" at all, unless you change the springs and shocks, so it shouldn't "feel" any different than before, if those were left stock. If anything, the impact harsness might be higher, as the suspension has less room to move before it hits the bump stops, at which point, the suspension ceases suspending and the rubber bump stops become the suspension. Thats bad for the car. And terrible for handling, as the car will go into instant under or oversteer, depending on which end bottoms first.
Generally speaking, and of course it's impossible to tell from pictures, is when cars are lowered, springs are changed to stiffer units to control the cars movement better, as there is now less suspension travel available before the car bottoms out on the bump stops. And when you change springs to stiffer units, you need to change the shocks to stiffer ones as well, to control the higher frequency of the springs. They go hand in hand.
Honestly, lowering your car to match a picture takes none of the important issues into consideration, and is merely cosmetic, at the possible expense of suspension dynamics.
My opinion, sorry, is to find a shop that KNOWS, like TRE in the states, (as just one example) what happens to the car when lowered, and follow their recommendation. If TRE were to say that they would lower it that far, but that you should change the springs and the shocks and add a rack spacer kit, I would know that they weren't just trying to 'sell' me something, but that they were protecting me from myself!
Now, your car may be fine...I don't know your particular model well, but I do know that your method is inviting trouble.
Elombard 05-12-2006 03:49 AM
Yah you can only lower are car so much before the suspension is out of its design perameters. Then you have to start moving pickup points etc. Thats why TRE extends the lower a arms, spindles are raised etc. and why race 911s have adjustable inner mounting points for the rear bannanas. Not saying yours is too low just making sure we are all on the same page.
Rad Hatter 05-12-2006 04:00 AM
Thank you
Thanks very much for your reply.
;) Rich
Miguel Antonett 05-12-2006 05:22 AM
After all... everyone has a different set of values, IMHO you want to enjoy your car for whatever reason you have (i.e. looks, handling, performance, show-off, purist, car nuts, toy... all of the above)
This forum is GREAT!!!!!!
imcarthur 05-12-2006 05:38 AM
I am certainly no expert - rank amateur actually - but Jake makes a very good point. Do a search on the hundreds of ride height threads & after you wade through all of the fender measurement comparisons, you will find some posts & discussions from some pros.
What is the angle of your A-arm? Is it level? Does it slope towards the wheel or away from it?
http://forums.pelicanparts.com/uploa...1147437006.jpg
This is a pic of a more or less level A-arm. My understanding is that you want level or a slope towards the wheel. When you slope the other way, you are shortening the travel of your front shock as Jake pointed out. I ran last summer with mine slammed down (slope down from wheel). Other than countless driveway issues, I thought it looked great & felt fine. But 3 times, I hit a slight pavement change at speed that felt like I had NO suspension. Not good at all. I went higher to back to level A-arms & it's fine now.
So, it IS a system & must be treated as same.
Ian
ps looks like I need a wash . . .
Rad Hatter 05-12-2006 06:57 PM
great input
Very interesting stuff...will investigate
Cheers and thank you for the time you took to do that.
Much appreciated
Richard
JR_NYC 05-12-2006 07:39 PM
This is my SC and I can tell you on the street the ride can be punishing when you hit expansion joints or even mildly deep pot holes. And when I hit a big hole I feel like I might tear a piece of the car off. One of these days I will need to have it adjusted and possibly swap the Bilstein sport shocks for HDs.
http://forums.pelicanparts.com/uploa...1147487884.jpg
GaryR 05-12-2006 07:50 PM
Originally posted by JR_NYC
This is my SC ...
Please take a picture in the daytime.. :D
I think it looks PERFECT but be sure the bump steer has been set. Here is my (dirty) 964 lowered a bit with 18" Fikse's...
http://24.151.4.182:90/Porsche/Amazon/Amazon-1.jpg
GaryR 05-12-2006 07:54 PM
For SHAME! Here you are in CT with some of the best shops in the US and you reference TRE! Hairy Dog, Musante, Farnbacher Loles to name 3!!! Fo Shame!!! :D
lateapex911 05-12-2006 08:07 PM
You missed Jim Newtons Auto Associates! And Fairfield County Motorsports! And Deman Motorsports just over the Tappan Zee. (Rick did my motor)
I know, I know...there are dozens I could have referenced...but he's in Hong Kong...so I tried to mention a shop that's famous on this board, with a poster or two that have actually discussed roll centers and bump steer. (Tyson and Dave)
His shop may, or may not be capable of a correct set up, I just don't know, but suggesting what to ask and look for, was my goal.
Rad Hatter 05-12-2006 08:10 PM
Correct Im in HK ==the info is helpful thanks :-)
MOMO3.2 05-12-2006 08:26 PM
lateapex911/Rad Hatter:
TRE Motorsports just lowered, aligned and balanced my 1987 Carrera. First, I installed Bilstein Sports, Turbo Tie Rods, ball joints and switched my 7's to the front and added 9's to the rear. TRE also added a rack spacer. The new height is: 24, 3/4" front and 24, 1/4 rear. Based on this Rad Hatter, you should be right on.
Mike
lateapex911 05-12-2006 08:32 PM
Right...theres three keys there....the stiffer dampers to help conttrol suspension movement adn reduce bottoming, the rack spacers to help return bump steer to stock settings, and the alignment. I imagine those ride height settings are intended to provide proper roll center balance.
GaryR 05-12-2006 08:34 PM
Mike
A rack spacer is the normal method to raise your steering rack to better level/align the tie rods after lowering the suspension assembly. Reality is it's done for most cars, I just did a TR6 suspension and used 3/8" spacers under the steering rack to level her all out to OEM specs.
