Actually, I think those ride height settings are intended to make me shout WAHOOO every time I go around a turn now.
Mike |
Perfect. I love the look..
Then again, I'm practically the same height. rjp |
What a difference an inch makes :-) Rich |
:D |
This one is a slight nose down at 24" front and back with SO3s, 225/45 and 245/45 16s. Only place I bottom is on steep drive ways with the long nose on the oil cooler.
http://forums.pelicanparts.com/uploa...1147368267.jpg |
At that ride height, I'd suggest upgrading the torsion bars to reduce the chances of the car bottoming out on a high speed dip.
I'd also suggest raising the rear a little. Visually, 17 or 18" wheel/tires look different on a 911 body at different ride heights, so a direct comparison w/16" Fuchs isn't the same. Here's mine for a comparison (slight rake). http://forums.pelicanparts.com/uploa...1147502980.jpg Sherwood |
Gotcha ...good point
Thanks buddy |
This is my car after lowering it.
http://forums.pelicanparts.com/uploa...1147616691.jpg I like the look of the ride hight, I would have liked it a little lower but it rubs as it is now when pushing a corner. http://forums.pelicanparts.com/uploa...1147617118.jpg http://forums.pelicanparts.com/uploa...1147617141.jpg Need bigger swaybars... |
mine today>>>>>>>>better scans
Full tank of gas - great handlinghttp://forums.pelicanparts.com/uploa...1147618541.jpg http://forums.pelicanparts.com/uploa...1147618594.jpg http://forums.pelicanparts.com/uploa...1147618642.jpg http://forums.pelicanparts.com/uploa...1147618704.jpg
Thanks Folkshttp://forums.pelicanparts.com/uploa...1147618766.jpg |
Rad Hatter, are those 9” Fuchs in the back? Did you have to do any modifications?
Thanks |
8's
Hi mate '''not 9's these are 8's
Cheers Richard |
And you have 7's in front ?
Looks very nicehttp://forums.pelicanparts.com/uploa...1150595008.jpg
Now you have to buy bigger t-bars to compensate for the softer ride that has resulted. Cheers, Joe |
| All times are GMT -8. The time now is 04:57 PM. |
