| Registered |
				MFI Intake Backfire
			The facts: Newly rebuilt 2.4T, JE Pistons @ 9.0-9.5 CR, ported T heads, 91 Octane, E Cams, T MFI Pump and Throttle bodies w/57K miles useage. The Story: Runs very strong and rich, with lots of HP for a little 72. However, at idle I get what I believe is an intake backfire/click sound once the engine is warm. Will this hurt my engine's longevity? Can it be eliminated? Due to the car's low mileage I do not suspect excessive wear in the TB's. The solution: ?
				__________________ David 1972 911T/S MFI Survivor Last edited by daepp; 05-11-2006 at 01:41 PM.. | ||
|  05-11-2006, 08:00 AM |
| Registered |
			Bump Anyone? Bueller?
				__________________ David 1972 911T/S MFI Survivor | ||
|  05-11-2006, 08:36 AM |
| Registered Join Date: Jul 2000 Location: Williamsburg, VA
			I have the same issue with my Webers.. I have read over and over agin it is mostly caused by a lean condition due to air leaks or miss jetting or?
				__________________ Kerry (Back on the road, sort of) 914-6 in the Werks | ||
|  05-11-2006, 10:06 AM |
| Registered |
			Has anyone ever suggested that it can damage the engine? And what about changing the timing?
|  05-11-2006, 12:09 PM |
| Senior Member Join Date: Feb 2000 Location: Lacey, WA. USA
			Intake popping is usually a sign of a lean running condition.  But ignore that and listen to this:  Every reliable bit aof advice I have seen here on this subject suggests that you carefully follow the MFI tuning procedures.  Measure, Check, Adjust.....or something like that.
				__________________ Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" | ||
|  05-11-2006, 12:28 PM |
| Autodidactic user Join Date: May 2003 Location: Summerfield, NC
			"Popping" is usually caused by a too lean condition but it can also be caused by a too rich condition.  Since you stated that your car was "very strong and rich" I'd look into the mixture being too rich.  What the popping symptom is telling you is that the plugs are not firing correctly which is usually a mixture issue but could also possibly be an exhaust gasket (maybe even a head gasket) leak.  I would work my way back through Mechanical Fuel Injection, Check Measure Adjust in exact detail to get your mixture correct.  Also take a look at the links under my signature for lots of good MFI information. P.S. If you put MFI in your subject line next time you'll probably get more responses. Us MFI guys like to stick together.
				__________________ Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.  1973 911E Targa (MFI) Last edited by David E. Clark; 05-11-2006 at 01:34 PM.. | ||
|  05-11-2006, 12:43 PM |
| Registered |
			Superman and David (SuperMFI Guy) Clark:  Thanks for the info. With respect to CMA, is it true that it is only reliable for stock setups? Having changed such things as air/intake flow and CR, I suspected that the CMA would not "calibrate". The pump has been leaned (?) out a bit to improve idle, but it's still quite rich. It's rich to the extent that it'll make your eyes water with the top off at a stop light! Of course, when you get on it, it goes like hell. It also idles pretty good. However, am I ruining my intake valves, seatsor guides?
|  05-11-2006, 01:47 PM |
| Registered |
			Bump
|  05-11-2006, 07:19 PM |
			Uber, I only have experience with the stock MFI system. Like you, I have read that MFI is really only applicable to the stock system. My impression is that the specific details may not apply if you have a modified system but that the general outline for checking the system is still applicable no matter what you have done to your MFI system. Even though you have a modified system, I would go back through my system in the order suggested (mandated): 1) Air cleaner cartridge 2) Compression loss 3) Spark plugs (spark plug connectors) 4) Dwell angle 5) Ignition timing 6) Fuel pressure and flow 7) Injection nozzles 8) Injection timing 9) Correlation 10) Exhaust emission test a) at part load b) at idle speed No matter how you have modified the system, it still, for example, won't run correctly if you have a bad cylinder from compression loss. After going through the above sequence, and if you do determine that you have your MFI pump set too rich (and how can it not be if it makes your eyes water at a stop light!), remember the phrase "I Lean Left" for "idle screw lean to the left-- and then remember that the main rack is the opposite of the idle rack, so the main rack is lean right, rich left. Seems like I always need to remember this. As far as to why your car seems so rich at idle but still runs great. Tyson Schmidt posted this explanation of why MFI cars run rich at idle but get leaner when they are driven hard in this thread. Quote:
 It goes without saying that since a gas/oil mixture doesn't lubricate very well it will ruin your valves cams, rockers, chains, etc in no time. My bottom line: If your eyes are watering at stop lights from breathing in gas fumes caused by rich running, you absolutely must get this fixed or you risk killing your engine from lack of proper lubrication. Hope this helps.
				__________________ Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.  1973 911E Targa (MFI) Last edited by David E. Clark; 05-12-2006 at 02:43 AM.. | ||
|  05-12-2006, 02:40 AM |
| Registered |
			The depth of this BBS never cease to amaze me! Thanks for the great info, David. Your suggestions look like a good 12 step program. I'll post the results once everything is checked. David
|  05-12-2006, 08:05 AM |
