Top end rebuild cost?
I need a top end rebuild done on my '87 911. What have you guys been quoted or charged for having this done? I want to know what to expect pricewise.
Thanks |
coolcavaracing.com
Why do you need a top end rebuild?
Pål (Paul) - The Norwegian lost in Finland... 1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!) come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Engine is using a lot of oil, from one quart to one and-a-half quarts per tank of gas. The engine sounds like it's running on 5 cylinders because one of the spark plugs has been fouled probably because the valve guide has leaked so much oil.
...it depends, but I would say the minimum would be around $6,000.
Mine was $6,000 18 months ago. The car ('87) ran noticeably better afterward.
Jack 2007 GT3 gone but not forgotten: 1987 Carrera IROC backdate, '89 Carrera M491, '96 993, '93 964 RSA(two), '00 996, '97 Boxster, '79 911SC, '78 928, '76 924, '75 914, '74 911, '74 914, '72 911E, '72 911T/V, '71 911T, '70 911T, '66 912, '65 356C, '61 356B roadster, '60 356B |
(the shotguns)
Do what?! $6k?! What would be the breakdown on that figure?
Could you not just rehab the heads (guides, valves, clean up), put 'em back on and see how she goes? Maybe check specs on one or two cylinders while you're in there? Sorry to butt in, just shocked at the figure after reading Wayne's books. |
MBruns for President
3K for just a top end - maybe 3500 depending on the amount of valves being replaced. $6K bleah!
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Somewhere in the Midwest
Yep...$6K for a topend rebuild is too much. If you are going to pay $6K, ship your engine to me with a check for $6K, and I'll return your engine with a new set of wheels! (that's my way of saying I can rebuild you engine for less and you'll have money left over for a new set of cool wheels
)Heads can be R&R to stock for $500-$700. If you don't need any other new parts (e.g. cylinders), that'll be the largest "parts" cost. The rest are necessary seals and labor. Now if you upgrade some of the parts (e.g. cams and springs), figure another $1000 to your parts cost. |
